Coleman Powermate Generator Capacitor.
   / Coleman Powermate Generator Capacitor.
Thanks everyone for the suggestions and help, but problem is pretty well solved. No new capacitor needed. I found an online OP manual, and read down through it. Right in the manual it does say there are times it may not generate, if not ran for a while, and all it needs is excited with a 6V lantern battery. So I reckon' it makes it well worth the $35 I paid for it after all... :)
   / Coleman Powermate Generator Capacitor. #13
Nah, you paid way too much, it will fail for sure!(I'll take it)
The problem is generally the loss of residual magnetism in the rotor, which is needed to self excite the generator. (This is due to the quality of the rotor) A lot of times this can be overcome by starting the generator and letting it run for a minute or two, with nothing plugged in to it. If the rotor has the tiniest bit of magnetism left, it will slowly build up voltage in the excitation module and self excite. If you start it and plug something in straight away, then it basically shorts out the windings and loads it up reducing any residual magnetism/excitation to zero.
So when you start it next time after sitting for an extended period, make sure everything is switched off and unplugged, start it and let it sit for a few minutes running at full speed, then try a small load and see if you have a win.
Will do..!! Thanks..!!
After it started so easy when I was looking at it, I figured if nothing else, the engine was worth that to repower one of my old David Bradley's. WAY more hp than they need, but the price was right.
   / Coleman Powermate Generator Capacitor. #15
Hard to use the engine for a repower as the crankshaft end is tapered.
To tell how losing the magnetism is our 20KW air cooled Generac has a flashing circuit that uses battery power to flash the field on every start up and exercise.
David
1977 Gleaner A630 Corn Head (A55315)
1977 Gleaner A630...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
1607 (A57192)
1607 (A57192)
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
