coloring hydraulic fluids?
   / coloring hydraulic fluids? #11
The Kubota fluid is clear or light amber and the stick is irridite plated so you can't see the fluid at all.
What I did was to drill a hole (1/16") at the high mark and the low mark on the dipstick. Because of the oil viscosity, it will bridge the hole (upper and lower) when it's full and the (lower) and not the upper if it isn't. All you do is pull it out and look. /forums/images/graemlins/cool.gif
Easy, simple and cheap. I don't know why the tractor manufacturer didn't do it. /forums/images/graemlins/confused.gif
   / coloring hydraulic fluids? #12
I too drilled a small hole in the dipstick, It seems the best way I have seen to see the oil level.
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
(1) WHIRLPOOL REFRIGERATOR (A51248)
(1) WHIRLPOOL...
2024 JOHN DEERE 6135E LOT IDENTIFIER 244 (A53084)
2024 JOHN DEERE...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A51573)
New/Unused AGT...
JOHN DEERE 560M LOT IDENTIFIER 15 (A53084)
JOHN DEERE 560M...
2024 JOHN DEERE CP 770 LOT IDENTIFIER 22 (A53084)
2024 JOHN DEERE CP...
