Rotary Cutter Comments on Bush Hog Razorback cutter
   / Comments on Bush Hog Razorback cutter #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I'm looking at a used Bush Hog Razorback 60" cutter. Are there any known weak spots to look for. I notice this cutter is in the economy range with a shear pin only and no clutch. I'm just using it for a small yard area.
   / Comments on Bush Hog Razorback cutter #2
For many this unit is fine and there have been no problems with those we have sold.
The shear bolt vs slip clutch is equal ground for many. You will mostly be mowing the same piece of ground so shear pins will work fine as long as you learn where it hit's things and you need to take evasive action or to remove them.
   / Comments on Bush Hog Razorback cutter #3
I am a Bush-Hog fan..have their brush-hog,seven foot rear blade,tiller and box blade..the brush-hog (purchased new) has about 500 hours on it;beat up but still works fine; I have only broke two shear pins.I much prefer shear pins to clutches in a brush-hog.:thumbsup:
   / Comments on Bush Hog Razorback cutter #4
I'm sure Art knows what he is talking about but...
If you live in I give my slip clutch a work out every time I cut my pasture. The ***** gophers pile up a lot of dirt where the weeds are tall and I would be poping pins left and right.
2012 JOHN DEERE 850K WT CRAWLER DOZER (A51242)
2012 JOHN DEERE...
UNUSED X-STAR 250 GALLON FUEL TANK (A51243)
UNUSED X-STAR 250...
2012 Chevrolet Cruze (A50324)
2012 Chevrolet...
JLG 800A MANLIFT TELESCOPIC/SCISSOR BOOM (A51242)
JLG 800A MANLIFT...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52128)
2014 Dynapac...
2017 Vermeer SC802 S/A Towable Stump Grinder (A50322)
2017 Vermeer SC802...
