Rotary Cutter Comments on Bush Hog Razorback cutter
   / Comments on Bush Hog Razorback cutter #1
shaley
Tidewater VA.
Ford '92 2120
I'm looking at a used Bush Hog Razorback 60" cutter. Are there any known weak spots to look for. I notice this cutter is in the economy range with a shear pin only and no clutch. I'm just using it for a small yard area.
   / Comments on Bush Hog Razorback cutter #2
For many this unit is fine and there have been no problems with those we have sold.
The shear bolt vs slip clutch is equal ground for many. You will mostly be mowing the same piece of ground so shear pins will work fine as long as you learn where it hit's things and you need to take evasive action or to remove them.
   / Comments on Bush Hog Razorback cutter #3
I am a Bush-Hog fan..have their brush-hog,seven foot rear blade,tiller and box blade..the brush-hog (purchased new) has about 500 hours on it;beat up but still works fine; I have only broke two shear pins.I much prefer shear pins to clutches in a brush-hog.:thumbsup:
   / Comments on Bush Hog Razorback cutter #4
I'm sure Art knows what he is talking about but...
If you live in I give my slip clutch a work out every time I cut my pasture. The ***** gophers pile up a lot of dirt where the weeds are tall and I would be poping pins left and right.
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
