Common rail vs mechanical injection
   / Common rail vs mechanical injection #1
Cow pi
Case Maxxum 125
I'm looking to buy an older Case Maxxum 125 for an all around ranch tractor. What are the pros and cons of common rail injection vs mechanical?
Is there any difference in fuel economy? Long term maintenance?
I'd appreciate any input.
   / Common rail vs mechanical injection #2
Why that tractor? (There are two versions a tier 3 and a turbo tier 4)
I imagine it is in the lower price range based on its testing performance by the dept of ag?
   / Common rail vs mechanical injection #3
A common rail is usually self-priming at the injectors.
A mechanical injector is a lot cheaper than a common rail injector.
A common rail will usually be more fuel efficient since the computer controls the pulse width and will adjust for load.
Clean fuel is the most important thing. Filters are cheap compared to injectors or injection pumps.
   / Common rail vs mechanical injection #4
Common rail needs a computer. Computers run on electric. Electric and water do not mix and if the water gets in the computer, the engine usually stops, and the man who has to fix it usually gives a sharp intake of breath and smiles. Mechanical pumps, provided they get a steady flow of clean diesel, keep going. They usually use a bit more fuel, don't produce as much power, but they keep going. And they keep going. Mechanicals don't have EGR or DPF to worry about and give off more CO2 etc. so the owners are not so popular with tree hugging environmentalists that think we should all be using horses.
   / Common rail vs mechanical injection #5
Ditto on common-rail requires cleaner fuel than older style IP. My neighbors Kubota M8560 got water in fuel allowing fungi growth in fuel system. Fuel pump & injectors had to be replaced to the tune of $7500 at local dealer.
I've had water get in fuel systems on my Kubota M7040 & Ford 6700 due to my storage tank water contamination. I just drained water from tractor tanks, installed new fuel filters & added fuel conditioner that contained Biocide. That was several yrs ago & tractors will operate today
   / Common rail vs mechanical injection #6
You will love that tractor. Parts are really common and maintenance is very easy.
Long term, mechanical injection is simpler and easier to maintain. Common rail a bit more efficient since it’s computer controlled and can be more powerful with the time ing of the fuel injection events.
   / Common rail vs mechanical injection #7
To me the really big plus for the common rail is cold weather starting, it is fantastic when it works right.
I don't like the necessary electronics and the worry that they may fail at any time.
The common rail will produce a bit more power a bit cleaner.
   / Common rail vs mechanical injection #8
But then, soon as we go back to horses and drag all the plows out of the thickets and brush....they will start belly aching about all the methane from the manure....
   / Common rail vs mechanical injection #9
Interesting that the "efficiency" myth continues after the whole dieselgate thing.
High pressure common rail is not any more efficient than mechanical. The injector nozzles determine the maximum flow and pattern.
However, the Teir 4 version if that tractor will seem more efficient as it utilizes a turbo. By under tuning and requiring the turbo to activate for full power there is a perception of fuel economy.... at a significant parts and maintenance costs when something fails.
So if you want to pay a few dollars less to refill the tank and a few hundreds more maintaining, that would be the version.
There has been very little advancement in diesel efficiency in the last 50 years other than a rotary diesel engine that was released a year or two ago (half size, same power density).
   / Common rail vs mechanical injection #10
Sorry you are mistaken
Giyi Mini Quick Attach Pallet Fork (A44502)
Giyi Mini Quick...
Kubota RTV900 4x4 Utility Cart (A44572)
Kubota RTV900 4x4...
40ft Shipping Container/ Tiny Home (A44391)
40ft Shipping...
OKC-NICHOLS HILLS PROPERTY (A45333)
OKC-NICHOLS HILLS...
2018 INTERNATIONAL LT 625 TANDEM AXLE SLEEPER (A43003)
2018 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2018 FREIGHTLINER...
