Compare L35 To A B21
   / Compare L35 To A B21 #11
I don't think you will regret buying the L35. It is a lot more machine than the B21. If you have major league rocks, it is the one to get.
As others have said, single owner beats rental by a mile. Someone may have found the exceptional rental yard that actually does maintenance on its machines, but everything I have ever rented has been a tired, worn out POS. Think about your own experiences renting stuff.
I have a hydraulic thumb on my JD110. On a scale of 1 to 10, no thumb is a 1, mechanical thumb is a 4 or 5, and hydraulic is a 10.
   / Compare L35 To A B21 #12
The L35 is a lot more machine than the B21. With the rocks you describe you will want that extra capacity.
Go for the hydraulic thumb. I have one on my JD110 and on a scale of 1 to 10, no thumb is a 1, mechanical thumb is a 4 or 5, and hydraulic is a 10. Really handy for working with rocks.
You do not want a rental yard machine. Oh, someone might find a gem every once in a long while, but most of the time the equipment they sell is worse than what they rent. I have never rented anything that was in perfect shape, and most of it was pretty sorry.
Well I did it! Just bought the B21 for $15,000. The deal for the L35 never materialized. All in all the B21 is in great shape for a rental. Everything is still tight no lealks. Used it before purchasing moving some dirt and some 2x3 rocks. Small dent on the seat canopy and one work light needs to be replaced which I'll fix. Seller will deliver 73mi to my door included in price. I'll change all the fluids and look to put some kind of thumb on it. Sorry for not taking everyones advice but I think I will be very happy with it.
   / Compare L35 To A B21 #14
Congratulations RobbieBones, If yours is as good to you as mine has been to me you will be happy. Let us know what you decide to do about a thumb. I've always wanted one and never got around to doing it.
MarkV
Thanks Mark.
I will be needing a toothbar also. The bucket has a bolted on cutting edge, which toothbar will work? Do I have to remove that cutting edge first?
   / Compare L35 To A B21 #16
Mine is an ex rental. It was well serviced and only needed the brake cable tensioned.
Regardless of how well the rental company treats their machines as soon as the renters get out of sight they hammer the (comment adjusted with respect to Bird) living tar out of the machine. I'd stay clear of a rental.
   / Compare L35 To A B21 #17
Sorry I didn't know you'd bought it when I posted but hey it's up now so I can only wish you the best now.
   / Compare L35 To A B21 #18
Robbie, Congratulations on your new piece of equipment, as for the tooth bar over a bolt on cutting edge, do a search for RichT , he fabricated one, and gives all the contact info for the shanks and teeth. After searching around for a TB for my B-26, I gave up, and had one built. The cost for the teeth and shanks was about $120 with shipping, then I printed out the pictures that RichT posted and took them to my welder friend, and he had it done in 2 hours. I've been using it for about a week now, and it works great! also I reccomend filling the tires on your machine, it made a world of difference in the stability on mine. Travis
   / Compare L35 To A B21 #19
Thanks Mark.
I think my tooth bar is from Woods. No I never removed the factory cutting edge. It sure does make a difference when you put one on. Mine hasn't been off in nine years. The other mod that makes a big difference is loading the rear tires with ballast. I used water and the non toxic antifreeze. It was easy to do at home with an inexpensive valve and drill pump.
MarkV
   / Compare L35 To A B21 #20
I have the Bro-Tek mechanical thumb with the B21 and lots of rocks here too - 3-5' variety (and bigger) - cant lift them but do push up to 3-4' into position with the FEL/BH. The thumb is good for smaller rocks 1-2' typical, however the Bro-tek seems better suited to the BX series than the B21. I have bent the 3PTH connecting rod (I had a spare) and the pivot points are a bit loose after building a 200' wall two years ago. It still works and as others have said a mechanical thumb is better than none at all.
Hindsight I would have gotten a more HD serated thumb with a fixed extension bracket that allows for several positions, then a Hyd Thumb would be perfect but thats not in the budget, but all in all I am happy not visiting the Chiropractor due to the "thumb".
Good luck with your purchase and enjoy the experience..
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2012 Honda Accord Sedan (A51694)
2012 Honda Accord...
Electric Mobility Scooter (A51694)
Electric Mobility...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
