Sid Post
Platinum Member
- Joined
- May 28, 2010
- Messages
- 775
- Location
- TX and OK
- Tractor
- Massey 5711D, Kubota L4600, Kubota B2601
First, in real terms, there is a bit less than $10K price difference depending on the exact Kubota difference. My most expensive option is replacing a tractor that doesn't do what I need it to!
I grew up on BIG JD iron (~150Hp) and currently own a Kubota B2601 and L4600. I'm finding the L4600 to be too light overall, especially in the rear. With a big rotary mower on back or my tiller, it is very light on the front without ballast in the loader bucket. I do a lot of heavy loader lifts and it is too LIGHT in the rear end even with loaded rear tires. In soft sandy ground (East Texas) or wet ground, the L4600 is basically helpless with any real load on my land which is NOT flat, the bigger the slope the worse the problem is.
I am generally in wide-open spaces so I have few limits on real tractor size. With the MF4707 sporting an FL3615 loader, it will have the soft drive loader just like the Kubota M6060/M7060. I mow a lot and can possibly see a small bat-wing mower in my future. I also do a lot of loader work so, I am somewhat biased to more is better. The MF4707 has a clear weight advantage so, loader stability along with a bit more size will be super helpful and safer when on sloped ground. An M7060 versus the MF4707 is at least ~$8K more expensive and the M6060 is close to ~$10K.
What I am having a hard time differentiating is WORK CAPACITY differences in the MF4707 versus the Kubota options for the cost difference. I don't want to massively overbuy but, I can live a lot easier with too much tractor versus not enough, even by a relatively small margin.
The L4600 is 99% likely to be sold or traded in and, the sweetheart B2601 is apt to move to the nursing home with me when that day comes!
In the end, dollars matter but, so does work capacity. If the M7060 will do everything the MF4707 will but, take more time to accomplish the task, that is a factor as well.
TIA,
Sid
p.s. I hope everyone's vote is counted today! :united-states:
TIA,
Sid
