Comparing slip clutch rating to shear bolt rating
   / Comparing slip clutch rating to shear bolt rating #11
I just follow the general slip clutch directions and continue 1.5 turns. Seems to work.
Same here with one exception. Every spring I'll back off the spring tension bolts on all the slip clutches and slip them with the PTO a few dozen revolutions to remove any corrosion that might have got there over the winter from sitting. I measure the bolt protrusion (base to head first so I can reset them to the slip torque spec. You don't have that issue where you are, but I'd still slip them once in a while if the equipment sits outside in the weather or you wash it.
   / Comparing slip clutch rating to shear bolt rating #12
I adjust mine every few years. My cutter sits under a carport type of steel shelter, protected from heavy rain, but still gets moisture from blowing snow. Humidity is low where I’m at except during the summer monsoon season when it is humid. When I do slip it, it’s never been locked up.
   / Comparing slip clutch rating to shear bolt rating #13
I've started doing the same thing. My neighbor had a relatively new JD bush hog he bought with his tractor, probably only 3 years old when he tore the PTO shaft all to pieces when he hit something. Asked me to help him look at it. Turns out the slip clutch plates were rusted/corroded together and didn't provide any protection. I would guess his mower sat outside on the dealers lot for who knows how long, then he had it 3 years. That was enough to freeze the plates together.
One other thing I do is check the temp of my clutch right after every time I use it by carefully touching it in case it's hot. If it's hot I know the clutch has started slipping and I can adjust it before the plates are burned up.
   / Comparing slip clutch rating to shear bolt rating #14
I don't have to go to the lumber company
for the bolts as my dealer is sending me some
Nice guy Mike
willy
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55314)
2008 Ford F-250...
toro turf sweeper (A50324)
toro turf sweeper...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
