Pilot
Veteran Member
- Joined
- Nov 20, 2004
- Messages
- 1,219
- Location
- Oregon
- Tractor
- JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Looking at a 750 with 1,100 hrs., a 770 with 1,200 hrs. Both appear to be well maintained, both have loaders, but the 750 has a JD loader & the 770 has an SMC, which seems to work a little faster. The 770 has wider tires which are a plus for my ground. Tire wear appears about equal. Both are 4WD. Asking prices are $7,950 for the 750 & $9,500 for the 770.
I would like to keep my costs down, but I like the wider tires on this 770 & I like the fact that it is newer, but I know that in itself is not too important.
What are your thoughts on the pros & cons of each? Use will be just general work around the place, maintaining a 1,200 ft. gravel driveway, spraying, tilling, etc., probably working it less than 40 hrs. a year.
What are your thoughts? Pros & cons of each? Any experience with both?
Thanks for any input.
