Compressed air on pickup
/ Compressed air on pickup #1
TRR
Central Texas
Kubota L235
There was a thread about compressed air on pickups. Here's what I did to put it on my F250. The mounting pad I built out of the C purlin material left over from my barn to match existing holes in the truck's frame. The compressor, tank and relay are from VIAIR with fittings from various sources. It's wired to one of the upfitter switches in the cab. Note: this is NOT a high capacity pump. This system is intended more for adjusting air pressure in tires when I'm towing long distances. It can run my air impact wrench for tire changes, but will be slow doing so. I've given some thought to adding an air horn like a semi, but that's still under consideration.
/ Compressed air on pickup #2
Nice setup. I chickened out and mounted mine inside my toolbox. They use way to much salt on my roads to risk keeping it under my truck. I hooked mine up with a relay for fear of to much amp draw for the upfitter switches. I think my tank is an 8 gallon and for little jobs or emergencies it works surprisingly well, even running an impact.
/ Compressed air on pickup #3
That would last about one winter here and be junk. Mine is behind the rear seat in my crew cab Ford. inflates the air bag system on the rear axle, fills the tires in an emergency and blows the train horns under the hood.....
/ Compressed air on pickup #4
Very slick install. Like others said, around here salt would kill it dead. I even had to change my trailer connection so I can throw it back inside the rear hatch when I'm not using it, the salt completely corroded it in one season when I had it mounted externally.
I agree about the salt and a short life. Fortunately I live in the south where salt is not used, and I make it a point to always be south of the snow line.
/ Compressed air on pickup #6
That is cool! And exactly what I have been wanting to do on my F350. I have the Viair portable pump kit which is really nice, but a built in tank would be very handy. Got any more pix of the set up? How big a tank. Want to walk us through how this was done (or better yet, come to S.C. and do mine!) Which Viair kit did you buy?
I hear that SC has some pretty good BBQ. I'm visiting family near Baltimore, so maybe - - -
The hardest part is the bracket that holds the pump and tank. I cut up a piece of 8" C-purlin about 38" long and welded it back together. The hardest part is to get the brackets in the right place and the holes in the bracket to line up with the holes in the frame. There is a DEF line that runs along the outside of the frame in that location so you have to be careful with that. I dropped the plate about 1/2" below the frame to be sure I did not interfere with the DEF line. I clamped the mounting pads to the bracket and the truck frame so everything was in position. Then took everything but 1 mounting pad apart and welded the pad. Put everything back together and repeat until all pads were welded. Then it was time to drill the holes. I used a laser pointer and set it so the beam was in the center of the hole on the truck, then put the bracket in place marked the laser point, took everything apart, drilled the hole. Then repeat for each hole, but putting in bolts where I drilled the hole. Kinda laborious, but all 4 holes line up properly. The three pads are nothing more than an "L" bracket. I needed someplace that was protected for the relay so I turned the rear pad into a "U" shape with a top by welding another L shape to it. (Does this make sense?)
As for how the tank and compressor go together I used Viair's diagram. I have a pump relay controlled by the pressure switch and a blow off valve for safety. The compressor I used is the 380C which is rated to 200psi, the tank is 2.5 gallon/ 6 port also rated to 200 psi. The pressure switch is 110psi on and 145psi off, the blowoff valve is 175psi. All from Viair (including the relay) ordered thru hornblasters. The various 1/4 turn valves, gauges and brass couplings - (most came from the surplus center that advertises here) with one or two items from the hardware store that I missed in my order with them. I have a gauge for the tank pressure and another for the line pressure from the regulator. Its hard to see under the truck when checking pressures so I have color coded the gauges so I know where the pressure is by seeing what color the needle is pointing to.
/ Compressed air on pickup #8
Thanks for the explanation. What year is your truck? I am going to put that on my to do list. Is that the biggest tank you could squeeze under there? How about air intake? I read some route a intake line with filter to inside the cab behind the back seat. Not sure if that really matters.
/ Compressed air on pickup #9
/ Compressed air on pickup #10
I always have a tank from these people on almost everything I drive.
POWERTANK - CO2 Air Systems
The good part it's portable and goes from vehicle to vehicle. Also I can use it in the field if air is needed. They fill up huge Tires in seconds. I can run air grease guns and power tools from this set up.
Costs about $35.00 to fill and tanks last about a year before I fill them up again.
My truck is a 2012 - F250. I had a deadline to meet on the install so not everything I wanted to do is done. The tank is the biggest I could find that met the diameter requirement and had a pressure rating posted. You can go with a bigger tank if you mount it a little lower. There's a lot more room under the truck than it appears to have. As for the air intake, right now it's at the pump, but I do want to move it inside the truck. Haven't even looked at how I'm going to do that yet. I also ran regular wire from the auto store and loom from harbor freight. After reading up on Ford's upfitter books, I need to replace the wire with high temp stuff and no one in town (including the custom shops) has the high temp wire. I will have to order it.
As for tank size, I'm not sure it's that significant. If you're going to be using a lot of air, you'll need a bigger compressor. I had occasion to use the impact wrench recently when towing a trailer. Used up the air in the tank very quickly and had to wait for the compressor to refill it several times. It beats having to turn the bolts by hand, just can't be in a hurry.
/ Compressed air on pickup #12
I did a similar install on a Jeep I had, no longer have it though. Someday I want to do the same on my Tundra.
Mine was an under-hood install. It was a two sate install, first involved moving the factory air filter box, then the compressor/tank install.
Here are the two links
Airbox move
Onboard Air System
That is a real nice install.
Question: What year is that Jeep? What motor?
/ Compressed air on pickup #13
...I used a laser pointer and set it so the beam was in the center of the hole on the truck, then put the bracket in place marked the laser point, took everything apart, drilled the hole...
That's a pretty clever technique for precisely marking holes. I will probably try that someday.
/ Compressed air on pickup #14
In the off road community it's quite common to have on board air. Some use the Viar stuff, some use CO2 tanks and some (me included) used a standard ac compressor off a Jeep Grand Cherokee or a large Dodge truck. They are capable of building pressures of up to 300-400 PSI or more in a matter of seconds. The only drawback to them is they need oil, I would just squirt some tool oil in the air intake every now and then. I had two 2.5 gal. tanks, one under the hood and one next to the frame opposite the muffler. I had the pressure switch, check valve and regulator on the inner fender and a quick connect front and rear. I could air up my 36 x 13.5 tires from 7-8psi to 28psi in a matter of minutes or run the 1/2" impact gun with no problems.
/ Compressed air on pickup #15
Quick question have you had any problems with anything like rock strikes damage? I am going to do something like this with my 01 Excursion but I plan to add the horns and a quick disconnect both front and rear if nothing else just for the show off value.
/ Compressed air on pickup #16
I have never had a problem with my set up. I wheel it too. :)
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
