Concrete Patio Built On Dirt???
   / Concrete Patio Built On Dirt??? #11
Gotta go with your feelings. I don't blame you for that. The re-bar will help, and will keep it a single floating slab.
Gotta wonder where the up-front talk was all about, and why, as to 4" of gravel. Just to set the hook?
Some pics of the finished project, or some even before, would be great. /forums/images/graemlins/wink.gif
   / Concrete Patio Built On Dirt??? #12
   / Concrete Patio Built On Dirt??? #13
The patio stone and concrete needs to be on the structural subsoil. They are putting your patio on topsoil, which is not only useful around the house but contains organic materials that will decompose and settle. Make sure your gang of hoser masons actually removes ALL the topsoil before they put stone in. Sometimes there is much more than 4"; in spots I have 12-16" in the pasture.
   / Concrete Patio Built On Dirt??? #14
Actually, not too much topsoil here. They cut my house out of a hillside and scraped away all of the topsoil. It's pretty much solid clay. There are some bare spots that have nothing growing on them after 2 years of being bare. I'll take some pics and post them tomorrow...
   / Concrete Patio Built On Dirt??? #19
How can placing the forms on top of the existing ground be the same cost as scraping, bringing in structural fill, and compacting. Sounds an auful lot like "bait and switch". Each activity has an associated cost and if you eliminate 3 activities you eliminate the cost. Don't forget disposal costs of the excavated material (truck and pit costs).
If I tried the same thing in my job I'd be asked for a "Deductive Change Order" to the contract, IF the engineer OK'ed the concrete placement on the ground.
I've never seen concrete poured on topsoil and grass but that doesn't mean it doesn't happen. I wouldn't do it at my house and I'm sitting on top of glacial till, basically a gravel pit. I would always remove the topsoil.
Can you ask for a cost breakdown of the job?
   / Concrete Patio Built On Dirt??? #20
9202 (A50322)
9202 (A50322)
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
2018 Toro Z-Master...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
