Confession Time . . .
   / Confession Time . . .
Thanks for the info, guys!
We do have Kubota dealers all over the place. The closest one for me is about 17 miles away. The tractor they recommended was the Kubota L2501 HST, with FEL, Land Pride RCR12 5’ mower, and Land Pride BB05 Box Scraper. The cost for that setup would be $20,570.
This is my first tractor so I feel a bit overwhelmed by all the options. I’m 42 and plan on living on this property for a long time. Would you guys recommend looking at a used tractor? I’ve been a little hesitant because I don’t know much about tractors and am afraid I might not know what to look for when evaluating a used tractor.
   / Confession Time . . . #12
We do have Kubota dealers all over the place. The closest one for me is about 17 miles away. The tractor they recommended was the Kubota L2501 HST, with FEL, Land Pride RCR12 5 mower, and Land Pride BB05 Box Scraper. The cost for that setup would be $20,570.
This is my first tractor so I feel a bit overwhelmed by all the options. I知 42 and plan on living on this property for a long time. Would you guys recommend looking at a used tractor? I致e been a little hesitant because I don稚 know much about tractors and am afraid I might not know what to look for when evaluating a used tractor.
If you've wrenching skills I'd always suggest used if you have time.
It took me about 4 months to find my B7610 and maybe a year to find my M4700. My required repairs so far (/edit since 2009) have been hydraulics (hoses and a fixed cylinder) and tires. Probably $800 on tires and maybe $200 on hydraulics.
You didn't mention a trailer in the Kubota setup.
I just googled Kubota L2501 and this popped up:
Kubota L2510 Tractor Packages
KUBOTA L2501 TRACTOR PACKAGES
$18,849 CASH OR $19,349 FINANCED AT 0% FOR 84 MONTHS WITH 20% DOWN AND APPROVED CREDIT; SOME RESTRICTIONS MAY APPLY.*
Our Kubota L2501 Tractor Packages are perfect for several applications. There is a little bit of everything you need in this packages including the L2501 tractor with front end loader, front grill guard, 5 foot box blade, 5 foot cutter, and 18 foot trailer to pull it all down the road.
25hp Electronic Fuel Injected, Clean Burn Kubota Diesel
Bevel Gear 4WD Front Axle
"Wet" Multi-Disc Hydraulic Brakes
Power Steering
8X8 Synchro-Shuttle Transmission w/ Synchronized Forward/Reverse Shuttle
Optional 3 Speed Hydrostatic Transmission (+$1265)
Kubota LA525FL Front Loader w/ 60" Pin-On Bucket
Front Grille Guard
60" Land Pride Box Blade w/ Reversible Cutting Edge
60" Land Pride Rotary Cutter w/ Shear Bolt Driveline Protection
18’ Big Ram Trailer w/ Dual 3500lbs Axles, Trailer Brake, New Tires, Ramps, and Tie Down Straps
So your dealer may be a little high.
   / Confession Time . . . #13
G'day Mate and welcome to TBN from Downunder.
I've read both of your postings and noticed one glaring omission: What are you going to be using the tractor for? What is the 'biggest', regular job that you need the tractor to perform?
Enjoy the site.
   / Confession Time . . . #14
I知 a city slicker who has been lurking around here for awhile to get an education on what I need to buy for my new 8 acre farm in East Texas. I appreciate the insight you guys offer.
Matt, welcome. I'm sure you'll get great help here.
I started similar to you about seven years ago, bought some land and chose to get a tractor, without much experience. I went used/refurbished (older Yanmar). Can't speak for the newer tractors, but older tractors (mine is 38 years old) are really simple machines. There just isn't that much too them, and they're built tough. Stuff doesn't break easily, and if it does break, the repairs are often within the "handy" skill set. Maintenance is very straightforward. Help resources on this forum are excellent.
I'm going to upgrade to a larger machine, and I'll choose the best value that meets my future needs, whether new or used. Don't regret for a moment having previously bought used. That tractor has done great work for me over seven years. If you can find a decent used tractor with the right features to match your needs/planned uses, and it's used, and has been reasonably cared for, it's very much worth considering. Set aside some of your purchase savings for potential repairs, and get to work.
If you like the idea of dealer support and a warranty, and can afford it, that works, too.
   / Confession Time . . . #15
Don't be fooled by the resale ratings people say about Kubota and Deere as I honestly don't see it when the numbers are applied as a percentage of the cost when new. At least around here.
That is at least when compared to LS Kioti Massey I do however see a difference with Mahindra and the couple branson tractors but haven't seen any local sales of TYM so cant even guess at them.
I would lean heavily toward the LS when comparing the tractors mentioned but would definitely operate/test run all and not make a decision till I knew for sure which I would be most comfortable on.
   / Confession Time . . . #16
   / Confession Time . . . #17
In that size class the Kubotas don't cost much more than the others but the resale on them is a lot better. Nobody plans to get rid of their new tractor, but people sometimes realize they bought something too small or large or have a change in life plans (hit by a bus). In central Texas, small Kubotas really don't depreciate much from what you pay for them.
I'm not in favor of any... but this is wise advice. The resale on Kubota's might really be worth the up front variance. You never know what might happen or what changes you might make. Also, Kubota's are so well thought of in most in most instances, that should you need information, parts, etc, there is likely some quick help available. Obviously, get your money's worth... but don't discount the depreciation too much.
This is coming from a JD owner.
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
2021 Ford F150 (A55973)
2021 Ford F150...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
2014 BMW X1 S Drive 28I (A56859)
2014 BMW X1 S...
