Confused about CK3510SE filters.
   / Confused about CK3510SE filters. #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I am working on a service spread sheet for my CK3510SE tractor. The manual gives a part number of for a hydraulic filter T2185-38031 & states a quantity of 1.
In the section on changing the transmission fluid & filter. There is a picture of 2 filters. (1) Hydraulic Filter, right side. (2) HST Filter, left side. I got under the tractor & it has both filters.
The manual only shows changing the hydraulic filter.
The service interval chart shows changing both the hydraulic & HST filters at 50 hours & then every 200 hours.
Are the hydraulic & HST filters the same part number?
   / Confused about CK3510SE filters. #2
Are they identically sized? Wouldn't be surprised if they were indeed identical, but sorry, I'm no help in confirming.
Idea: buy two, when it comes time to change, remove both filters. If identical, you're good to go. If not, put the HST one back on (no harm) and keep researching.
Yes they look identical. I could not find any part numbers on the filters.
   / Confused about CK3510SE filters. #4
One is the drydralic filter and the other for the HST mechanism.
Hydro Filter; Kioti T2185-38031
HST Filter; Kioti T5855-46531
   / Confused about CK3510SE filters. #5
They'll be two different filters as thearborbarber listed. The hst filter will have a much larger center hole.
Thank you.
At first I was impressed with the owners manual. Now I am not so much.
   / Confused about CK3510SE filters. #7
The manual is OK just remember it's translated from Korean and not originally written in english.
Those are the part numbers straight from my dealer.
   / Confused about CK3510SE filters. #8
I had the same issue with my NX4510. I have the owners manual and service manual, and neither is very clear. Had to dig to find right part number for HST filter, and it was expensive!! $140.00.
If I did not get an answer her, I was going to the dealer.
Thank you again.
That is expensive. The filters for my tractor are only about $31.00 each
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2017 FREIGHTLINER M2106 TELESCOPIC BUCKET TRUCK (A51406)
2017 FREIGHTLINER...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A55787)
2025 ZWB 59in...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
