Confused about lights...B7800
   / Confused about lights...B7800
Thanks all.
Lights on and working great. The Service Manager at the Kubota dealer was absolutely great. Spent a half-hour with me, gave me a whole relay harness and drew a diagram for me. Was already to do that when I mentioned the hot wire stubbed on the back. He tested it, said it would be easier to use that. So off I went with the relay and the diagram in case I ever wanted to redo it that way.
Bottom line...55 W forward, 55 W to the rear. Looking good and seeing well.
Appreciate your suggestions.
grae
   / Confused about lights...B7800 #12
as number two said make sure you have the alternator not the stock dynamo.
I changed my front bulbs to 50 watt halogens and added a single TSC 50 watt halogen (via that spare wire under the seat) to the back. Because I have a dynamo it drained my batterey dead when I had all three 50 watt lights on. I added a switch to that back light and only use it when needed.
I should buy the alternator as the lighting still isn't good enough at night when plowing snow with my ski googles on.
Or, does someone have a better idea?
   / Confused about lights...B7800 #13
meatwad said:
Hello,
There is a factory circuit for work lights, it does come out a the rear of the tractor wiring harness near the back turn signals. On my B7800, the circuit has a 20 Amp fuse. At 12 volts, that is 240 watts of power. I run four 50 watt lamps, 2 in the front, 2 in the back. I have a simple toggle switch I added in so I can turn the lights on and off. I have used the lights a lot and have had no problems at all.
Bob
I believe that is a switched line isn't it? By that I mean when you turn off the key the power is removed from the outlet.
Yes, that IS a switched line.
And I've had NO problems with stock front lights, the two 55's and the dynamo. Three lights might put you over the edge, however...
grae
   / Confused about lights...B7800 #15
I know this thread is old - but I'm new and had a thought.
There are several automotive LED lights now available that might allow you to add a lot more light without a lot more Watts.
Something to check out?
'FRank
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
Metal Sunfower Lawn Art (A55853)
Metal Sunfower...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
