confused
   / confused #21
hdb,
I was recently faced with a similar decision. I have ten acres (9 pasture). I looked very hard at the L3010. I'm convinced that it is a good machine. In my case, I went for a NH TC35D which I got for just $700 more (both had hydro, loader and R4's). I have a 6' cutter on my machine and it just sticks out beyond my tires. I just came in from rough cutting my field. Grass was 1' or more high and very wet (it was raining). I was cutting in high gear range and while I could hear the tone of the engine change, I never saw the RPM's drop much at all (less than 50 RPM change). At this moment I'm happy that I have a larger tractor. Plenty of room to stretch out and get comfortable plus plenty of ability.
Peter
   / confused #22
Seems like you got your answer. 40 hp would be overkill for 12 acres. I have 11 acres, all open pasture, 4 horses. L2500 (27hp, 22.5PTO), and a 5ft light duty bushog. The specs rate up to a 6footer but I think the 5 works just fine and the price jumps quite a bit for the extra foot. Anyway I can cut 3ft grass in 4th or fifth if I cut high. The L3010 would be an ideal tractor for your needs, actually a little more than you need but a lttle more is certainly better than a little less!!
   / confused #23
gerald,
Wen might not agree with you, he has the M6800, 68 hp Kubota, on 10 acres. Not sure how much or if he uses it on other acreage.
Rick Jay has 30 hp, I think on 2/3 of an acre.
Generally, hp/acre is not an exact science. I do think that there are some good comments here though.
JimBinMI
We boys and our toys!
   / confused #24
Yeah, it all depends on what you want to do with your land. I have 68HP on 10 acres (well my son uses it on his 5 acres too) and I could use it on some other property, too, but the real issue is always what you are going to do with your land and of course how much you want to spend for a tractor. The cost of a tractor and implements is significant, but over 25 years, it is about equivalent to renting a tractor and implements for three or four days a year.
I use mine to cut ditches for drainage and it takes a lot of power to push a blade into the ground to cut a ditch a foot deep and two feet wide with a single cut. A box blade can completely use up all the traction of very large tires and 4WD with both front and rear differential locks locked. A box blade full of dirt weighs close to 4000# and cutting while climbing a slight grade also takes a fair amount of torque and traction. Tillers can take a little or a lot depending on the size of the tiller and the condition of the soil. A rotary cutter normally takes little HP unless the grass is thick and/or high.
A tractor becomes your mule and it's ability to pick up very heavy loads is not an insignificant task. A pallet of feed can be over a 1000# and with two of them on a pickup to unload, you have to be able to get the front one out. Picking up heavy objects is also really nice, but the exact weight you can handle or need to handle depends on the tractor, ballasting, and the loader. Mine only handles 2200 pounds at full height, but that has not let me down yet. Pulling fence posts takes a fair amount of pull, but sure beats any other way of removing them. Moving materials is a lot different in the amount you can handle each load with a 4 ft, 5 ft, or 6 ft bucket. A 6 ft bucket can weigh over 2000#. Being able to pull a stuck vehicle out of the mud is sometimes convenient. The more you use a tractor on a small farm or ranch, the more things you find you can do. The older you get, the more important it becomes to have a good mule.
Kubota makes the best hydro transmission on the market, hands down. You cannot get a hydro in tractors much larger than 40 HP. Since you will probably never pull a bailer and may not cut your own hay, the necessity of a 50HP tractor is considerably less. I have a gear drive and that serves my purposes well. I normally go forward in one gear for several hours and a hydro would be of no real help to me most of the time. For the few times doing landscaping work around the farm, they are really worth having. They don't do as well with a sprayer, or fertializer spreader or anything else that the operation may be dependent on ground speed being predictable.
Finally on 4WD. Just can't say enough about how dissappointed I would have been if I had not got it. About 90% of Kubota Compacts are sold with it and about 50% of the M Series (40 HP and up Ag tractors). I had a 2WD before, and it is absolutely worth what it costs in a Kubota tractor.
The Ag tractors are actually a little cheaper than the L Series compacts, but do not have some of the neat creature comforts and conveniences, although I am hard pressed to say there are any that I miss not having on my tractor.
   / confused #25
Longs are pretty crude, Newhollands are pretty noisy, never heard of the other one. There is more than just orange paint that makes the cost of the tractor higher. Fuel enonomy, cleaner burning, quieter, smoother hydro or a strong Glide shift trans. If you are going to get a cutter for the back of it I would not waste my money on a little 5ft cutter for that big of tractor. I would get a Bush Hog squealer 84. Twin spindle, 84" wide, doesn't stick out as far back as a 5 or 6 ft single spindle does. It only requires 25 hp to run it. If ya want to just use and 5 ft cutter, get a smaller tractor like a B 2710 or B 2910. They are a real gutsy tractor for their size.
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
378503 (A51573)
378503 (A51573)
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
