Connector for electrical accessories?
   / Connector for electrical accessories? #1
ishiboo
Platinum Member
Oshkosh, WI
Kioti NX6010HSTC, Cat 279c
I am in the process of adding a 7-pin RV trailer connector to the back of my Kioti, so I can use a brake controller I have lying around and also activate the tail lights when I stop... as I do occasionally move it on the road with the tractor for some projects.
While I'm at it, I'd like to add a future accessory connector to the plate. I would like to have one reversible motor circuit (2 pins, ground and power which swap) for a linear actuator, one constant power, a main ground, as well as 3 additional positives which may be momentary or just switched. I could get away with 2 additional positives though.
The 7-pin RV connectors are inexpensive, durable and easily replaced... so I am thinking about using one, however I am wondering if there are any other connector type options so it would not get confused for the trailer hookup? I thought about a 6-pin round (since I don't have any of those), but am open to other ideas.
I might also add an Anderson connector for a future winch or other high-amperage device while I'm at it :)
2019 CAT 420F2 IT (A50854)
2019 CAT 420F2 IT...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
