The stop and go is a killer (stressful) on oil, so to speak. Ha, I am not a professionl on oil either; till learning here. If your oil does not have a good additive package it will break down quick or quicker then others. It might still protect “ok” but TBN could be very low, high wear numbers, high OXD and NOX, high fuel, high water, etc. If testing for TAN, it better below the TBN #. If not, you got problems.
My thinking is to do (1) oil test for around $15. Yup it is gonna cost approx $15. Once you get the results back, see how it does. If good see what the number are and maybe you can go longer with same oil. If not, see what areas are high/low.
The thing that somewhat bothers me is the Mobil does not condone extended oil changes anymore. So I do not know if that will be an issue down the road. Maybe, maybe not.
