Constantly breaking shear bolts on my cutter....help?
   / Constantly breaking shear bolts on my cutter....help? #21
A grade 5 bolt from China is probably equal to a grade 2 USA made bolt if you're lucky. :laughing:
   / Constantly breaking shear bolts on my cutter....help? #22
I have been using grade 5 for years and it always seems to shear when it should. I could not get anything done with grade 2, every time i hit a small clump of grass it would shear so I finally changed it to grade 5 and if I hit something it breaks like it should.
   / Constantly breaking shear bolts on my cutter....help? #23
I have a 6 ft Land Pride Rotary cutter for my 45 hp LS
I turn the PTO speed down as slow as possible but I still shear a bolt on startup? What is the deal? Should I have it lowered to come in contact with some brush to slow the blades ramping up? I was told to have it raised when starting. I don't think I ever used it without shearing at least 1. I cringe every time I turn it on.
Suggestions??
Thanks
Make sure the blades are sharp to reduce stress on the driveline. Try increasing mowing rpm and slowing ground speed. Ken Sweet
   / Constantly breaking shear bolts on my cutter....help? #24
To the OP, What's the answer to something bent or bound up under the deck surface? If you have a problem and don't solve it, even by going to a stronger grade bolt, eventually you'll break your PTO stub/gears in the rear end- then you'll wish you'd found out what the actual problem is/was.:confused3:
   / Constantly breaking shear bolts on my cutter....help? #25
Believe it or not, they are pretty accurate. Home Depot Bolt vs. USA Made | Offshore Suprise! - YouTube
Personally I always read the manual & follow what it specifies. There are a number of combinations that will work. But unless you read the manual you wont know what the engineers specified for that particular implementation. Just because grade 5 are specified commonly doesnt mean the engineer that designed your machine didnt specify ungraded or grade 8 for some reason.
   / Constantly breaking shear bolts on my cutter....help? #26
I had the same problem breaking shear bolts on startup with my 6' brush cutter. Solved it with a slip clutch on the brush mower.
The problem was not the mower. The problem was the harsh startup with the electric/hydraulic PTO (even at idle).
Everything seem to be fine. I can rotate by hand, blades are free. Once it's mowing I'm fine......usually. I got to thinking, I hit a clump of dirt one time and it broke the bolt too. I didn't think that was right since it's supposed to handle a 2" sapling...
Also when running, it's smooth, no vibration or anything like that. I would think if something was bent, it would always shake
   / Constantly breaking shear bolts on my cutter....help? #28
What is the size of the shear bolt? Have all the bolts that have been shearing from the same batch? Some chinese 3/8" Gr2 bolts can be sheared with hand tools quite easily, they are not all equal. I scrapped a lot of bolts because of this problem.
   / Constantly breaking shear bolts on my cutter....help? #29
It may be normal for your setup, I would use the recvomended bolt.
My RC2072 with slip clutch calls for a grade 8 bolt which regularly shears after about 20 hours use. I engage at 600 rpm etc. But the abrupt electric PTO clutch and rocks seem to batter it enough to fail. The clutch is set loose and even then... I think its the free play in the coupler that gives things a running start before the bolt binds up abruptly.
I got the first batch at TSC....My Father-in-law picked some up at another Hardware store...Those do seem to last longer but probably my imagination.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55315)
2-Row Peanut...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2022 Harley Davidson Electraglide (A55973)
2022 Harley...
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
