Construction material for portable generator sound-deadening box
   / Construction material for portable generator sound-deadening box #21
I am thinking that direction too. Simply redirecting the sound, vs. enclosing the genny entirely, would help with the air flow and heat issues.
I was thinking the box served two purposes, sound deadening and hiding the generator. If the box was built so that it could be opened up when the genset was running that would help the heat issues. My first thought was to be be able to open the box so that the wall of the box towards the house was used to buffer the sound. The other four walls would be removed to allow air movement. The problem with that idea is its PITA to build and use, there still might be a hot spot on one side of the genset, a partial roof would help with the noise and rain but then you get back to heat build up again.
The more I look at alternatives to the power company the more I appreciate their service and price. :laughing::laughing::laughing:
Later,
Dan
   / Construction material for portable generator sound-deadening box #22
From what I have read, putting a muffler on a generator isn't much worth the trouble, because so much of the generator's noise is from the motor itself, not the exhaust.
While it may appear somewhat arcane to most of us (me anyway, most of the time), proper acoustic engineering can accomplish quite a bit. The other thing I meant to mention was check out Generac standby enclosures - around here Home Depot used to have one mocked up in-store - a good friend of mine has one that runs on NatGas, it is impressively quiet, esp. with the lid closed.
Air cooled engines do tend to be inherently noisy - one of the reasons the original Bug was noisy for it's size. And... even as air-cooled engines go, not much engineering time goes into block-radiated noise with cheap genny engines.
That said, until you get to Honda, the "mufflers" on most small generators aren't much more than spark arrestors.
Design-wise, the cost/benefit goes something like "Cheap out on the spark arrestor - get sued by a major State when one of their Parks goes up in flames. Cheap out on a "muffler" - good luck to Joe Blow for suing us for hearing damage".
Dug back till I found the link I was talking about. Got a few details wrong (Gen type, etc.... ), but general concept was correct. Yes, you won't get Honda quiet with just a muffler, but the OP guesstimates 50% reduction and in the Comments one guy meaured "103 db of sound at the muffler of the original generator stock/ now 92 db noise at the muffler area of the modified generator currently" - using a similar bike muffler setup.
You have to read down, but the pictures don't make it clear that he is NOT supporting the weight of the new muffler with just the OE exhaust studs. He did fab up a relevant new support.
Joel's Garage: Quiet Generator Muffler
In looking back for that one today, I came across this one:
Quieten That Generator
Good history of what he did with mufflers. I like the welded flange + flex- hose approach, as it allows you to run the OE setup if you are in hurry or don't care about the noise, but allows the add-on muffler to be quickly attached. Obviously, fire safety would dictate appropriate attention/vigilance is needed when using an add-on like that.
Rgds, D.
   / Construction material for portable generator sound-deadening box #23
I tried everything. What finally worked really well is, I built a 30x40 barn around it.
I put it inside, open the back window, and close the door. Then, I can barely hear it.
Sorry, folks, but I may not have been clear that the solution, like the generator, must be portable. Although I would like a new barn...
   / Construction material for portable generator sound-deadening box #25
Uncle built a concrete bunker for his Genset 35 years ago and no problems... roof was also concrete.
Kind of resembled an a root cellar built into the hillside.
   / Construction material for portable generator sound-deadening box #26
I once ran a genset that had the pipe thread type of screw in muffler, (think it was a Tekcomish engine).I added 2 short lengths of pipe (like 6" + 8") and an elbow with the muffler screwed to the end.
I placed the genset on the ground and situated the muffler so that it was in a previously dug small hole in such a way that the muffler and exhaust was below ground surface.
This hole was perhaps the size of about a bit more than 1/2 of a 5 gal pail.
When that genset was running (from 8-10 ft away) all you could hear was the rattle sound of the valves, the earth absorbed all the exhaust noise!
   / Construction material for portable generator sound-deadening box #28
I don't know if anyone as mentioned fiberglass duct board or even dense glass as possiblities. You could attach the duct board yo the side of aluminum street sign for weather resistance/structure. Neither is cheap unless you can scavange them up.
   / Construction material for portable generator sound-deadening box #29
Even small engines greatly benefit (sound wise) from quiet mufflers. Case in point - we bought my son a 49cc scooter for cruising to campus (the idea gleaned after a summer vacation to Panama Beach - scoots everywhere - what a blast!!! ).
From the factory, this 49cc Honda clone's exhaust was quite and gutless. It had a difficult time toting around an offensive lineman. So I souped up the engine, including a performance (read loud) exhaust (ok, it's more like 80cc now :))
Long story to say - check into a high quality muffler that won't degrade your performance, but lowers the db's at operating rpm. Small engines can be very loud or very quiet.
Another thought, check out the generator enclosure on a few motorhomes. They have already spent the time and effort to create an enclosure to accomplish everything you are trying to do. Why re-invent this wheel??
Good luck
   / Construction material for portable generator sound-deadening box #30
Hey, I just remembered. I was at an outdoor town spring festival type thing a few weeks ago and they had two gennies running. What they did was to surround them on 3 sides with hay bales. Worked pretty good.
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2013 BMW 528i (A53424)
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
