Contractors ??
   / Contractors ?? #11
I would second the new roof concept, getting trusses premade would make it a big, but not gargantuan job. You would have a much better performing, looking, place when you got done. The difficulty is that the current roof peak elevation isn't enough to get you good drainage all the way out onto the new addition.
A separate place over a new garage kills two birds with one stone, though!
Chris
I agree that anything other than a new roof will be a compromise and will look patched together. While not ideal, a shed roof extended over the new addition would give the OP a 2/12 pitch, maybe 2.5/12 pitch. In our area here in the south, a lot of double-wides have 2/12 pitch roofs without leakage issues. That shallow of a pitch would be more of an issue in a place that gets lots of snow. The shed roof over our back porch is a 3/12 pitch and is no problem at all.
Obed
   / Contractors ??
I want it to look decent when it's done I may just have to go back to plan1
and the garage What I need is a Laundry room and the house is so small there is no where to put it!! If I was to build a garage I would use half for the laundry room and put a second bathroom and maybe a spare bedroom!!
   / Contractors ?? #13
most building codes require a minimum 4/12 pitch, at least around here
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
Yamaha (A55758)
Yamaha (A55758)
