Dino oils usually broke down in a mater of hours indicated by spike in temperature as the bonds broke. They would come out black. We ran synthetic mobil 1 it ran all weekend, aborted the test and inspected the sample it had not broken down.
In real world as others mentioned even synthetics still come out brown after several thousand miles as they've picked up contaminants from combustion gases etc.
So dino turns dark from too much heat, and/but, synthetic from too much contaminants? Not sure I believe your conclusions.
My engines run 220F max. At what temp does dino turn to the color black? Why?
I just changes the oil on a high revving 4 cylinder at 5k miles, as usual. Used walmart dino as usual. The color is brown, not black...
Just curious if you compared the product numbers/SKU to confirm it's really the same product? A 50% mark up at AZ seems high.
That still doesn't explain it.
it's also why I don't buy blends, I buy 100% syn.![]()
