Conversion on a 3020 JD to put a alternator on it gas model
   / Conversion on a 3020 JD to put a alternator on it gas model #1
dvaidm
Harding mn
3020 john deere and 50 john deere
Just was curious if there is a conversion kit to put a alternator on a John Deere 3020?
   / Conversion on a 3020 JD to put a alternator on it gas model #2
Should be relatively easy if you can find one that matches the holes so it will fit your brackets or build some custom brackets. I put a gm truck alternator on an old long 445. I used a self exciting (1 wire). It had a terminal to turn the light off on the dash once it was charging. You might have to hunt down another pulley. I did.
   / Conversion on a 3020 JD to put a alternator on it gas model #3
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
