I'll get a picture up, the bucket is pretty trashed. Plus I like the idea of bringing the load closer to the tractor and the increased visibility when moving round bales.This can get expensive.
If you had a welder fix up your bucket you'd probably save money vs making the change and buying a SS bucket.![]()
That seems like a good outfit. I see they make a SSQA adapter with adjustable bolt mounts for the pin size & spacing - no need to cut and weld the existing mounts on the old bucket.I know not "cheap". Have 2 from this company and well worth it. If they don't have the correct one they will build.
New Holland & Ford Implements & hitch adapters
New Holland & Ford Implements & hitch adapters. washburn Company can custom build. Made in Lamar, Mo USAhayspear.com
Making and placing the bushings is the hardest part of building brackets like that. If the bushings on your bucket are still good, I would cut off those brackets and weld them to this Skid Steer Hitch Adapter With Blank Heavy Duty Frame That bucket and brackets aren't going to be of any use after you do the conversion anyway. If, however, you've got sloppy bushings, as is often the case with a machine that old, I wouldn't bother and would just make new brackets.Which leads us pack to my post, cut off and weld on my original bracket or is there a pin bracket available I should weld on?
With SSQA, the load is further away, not closer. Your capacity will be reduced a bit.I'll get a picture up, the bucket is pretty trashed. Plus I like the idea of bringing the load closer to the tractor and the increased visibility when moving round bales.
clamp on forks and bale spears are definitely further away when using a bucketMaking and placing the bushings is the hardest part of building brackets like that. If the bushings on your bucket are still good, I would cut off those brackets and weld them to this Skid Steer Hitch Adapter With Blank Heavy Duty Frame That bucket and brackets aren't going to be of any use after you do the conversion anyway. If, however, you've got sloppy bushings, as is often the case with a machine that old, I wouldn't bother and would just make new brackets.
