convert from shear pin to slip clutch on my rotary cutter PTO, anyone do it?
   / convert from shear pin to slip clutch on my rotary cutter PTO, anyone do it? #11
Is the 908 a flail mower? My 917 is a flail & those have belts that will slip & function like a sheer pin or clutch. Makes the need moot.
If your input shaft is splined you need a PTO shaft that has a sheer pin assembly integral to the shaft. If the input is round with a big hole, the sheer pin connects the PTO shaft to the input shaft via that hole. There will also be a groove on the input shaft & a set screw on the PTO shaft goes into the the groove. That keeps the PTO on the input shaft after the sheer pin breaks.
A whole new PTO shaft is $100-200. I'd give the guys at drive-lines.com a call. Their website is only ok, but the guys answering the phones quote specs from memory. They might be able to help you out if you give them proper dimensions & requirements. They were helpful on sorting out a shaft to attach to my clutch with appropriate sized U joints.
2137 (A46502)
2137 (A46502)
2016 Peterbilt 567 T/A McNeilus 2511 25 CuYd Rear Loader Garbage Truck (A45336)
2016 Peterbilt 567...
2010 International 4300 U3-HK Hooklift Truck (A44571)
2010 International...
3007 (A46502)
3007 (A46502)
2016 Ford Transit 250 Cargo Van (A46683)
2016 Ford Transit...
2017 Club Car Precedent Golf Cart (A48561)
2017 Club Car...
