Loader Converting to skid steer attach on 20 series
   / Converting to skid steer attach on 20 series #11
Sawman, If you can't find anyone local to you, I know a great guy in Waco. He's been pretty busy since the folks on "Fixer Upper" have been buying so many steel letters, so it may take a couple weeks. I have a BL10A loader and can make a tracing from my bucket, or you can email one as a .pdf also
   / Converting to skid steer attach on 20 series #12
Thanks LincTex,
Someone from here has offered a set for me to buy if they can't use them.
If that doesn't come through I will trace and have them cut.
I have an 875 miller plasma cutter that will cut the steel, but no CNC table. I don't think my free hand cutting would work. But I have located a water Jet source here.
Once I have them I will be making the SSQA adapter. Seems to be the best option.
I have the 2007 3820i, not sure how close it is to your model. I haven't gotten my manual yet and cant figure this controls. (actually haven't even played with it)
On the right side where the 3PH lever is that controls up-down, there is another control with numbers 1-10 or 12. Do you know what that is ?
   / Converting to skid steer attach on 20 series #13
Thanks LincTex,
Draft control.
   / Converting to skid steer attach on 20 series #14
That sounds like a "Draft" control, used for pulling ground-engaging equipment like 3-pt mounted Moldboard plows (a.k.a. the old "Ferguson System")
It's not needed for post-hole diggers, box blades and pasture shredders.
You are not alone - - WTF is up with all the missing operator's manuals?!?!!?
I have a little selector switch below my ignition key & the decal is damaged.
I couldn't figure out what the heck it was for, until I *finally* found out on here it's for the electric PTO engagement.
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
