cool idle.....
   / cool idle..... #21
</font><font color="blue" class="small">( Is there any particular reason to idle a diesel that may have been running at 2000-2300 rpm for a couple of hours? )</font>
First I know nothing about the newer higher rpm compact diesels. And rpm's has little to do with the need to cool down.
If you're doing(example) deep tillage work and you have the engine under a load of about all it can handle without lugging, then the engine needs to cool down some before it's shut off.That's just one example. "The reason it needs to cool is so the valves won't warp." With farming on the decline most (not all) tractors are never loaded for long periods of time now. I just a few days ago wrote a reply about not having enough load in the first 50 hrs. to seat the rings on my FT. Once hay season started loading the tractor is no problem. When I hook that 90" CCM tiller to it the load is there also. /forums/images/graemlins/cool.gif
When I subsoil, pull a MOCO, round baler and that tiller for hours on end ,I always give the engine time to cool down when I'm finished. And on either of the tractors I have I can see the temp. needle going down while it's at a lower RPM. I don't go to idle for the cool down. I run 1,000 rpm's to cool. Reason being on older tractors the oil pumps sometimes get weaker. I want to keep enough rpm's on the engine to keep the oil flowing well while it's cooling also.
So my answer is yes it needs to cool if it's HOT from a load.
   / cool idle..... #22
L2800 & L3400 calls for a 5 minute warmup for engine oil and minimum 10 minute warm up for hydraulic fluid.
Stopping the engine: "After slowing the engine to idle, turn the key to OFF. Remove the key.
   / cool idle..... #23
All the UPS trucks in our area are gas. Only the over the road trucks are diesel. All delivery are gas at least in our area. Gas is a whole different subject.
murph )</font>
Around here, they're diesel.
Why is gas a whole different subject?
   / cool idle..... #24
To add a little more info, a diesel engine will run cooler at idle than at higher RPM. The reason for this is that there is an extremely low load condition at idle. This produces very little heat in the combustion chamber. Because a diesel has unlimited airflow, it tends to cool itself from the inside.. This may not be reflected in the coolant temp too quickly though.
   / cool idle..... #25
I guess it's possible it isn't necessary on todays tractors. I do remember in the 70's a MF dealer and a IH mechanic telling me to cool the engine down after a hard days work. I just got in a habit of doing it. It doesn't take long. When I see the temp. needle start down, I give it maybe 5 min. Most of the time my cool down takes place driving back down the highway. I do remember a post on a farm site telling about an Oliver tractor having warped valves and it was stated that it came from shutting the engine off while it was HOT.
   / cool idle..... #26
</font><font color="blue" class="small">( </font><font color="blueclass=small">(
murph )</font>
Why is gas a whole different subject? )</font>
The original question was pertaining to a diesel engine. And some manufactures do say on a diesel to cool down. I have never seen a manufacture say a gas engine needs to cool down.
murph
   / cool idle..... #27
I would say that the gas engines produce as much heat at idle as they do under a load. Its always working against the throttle plate, creating a load in itself.
   / cool idle..... #28
My manual does say to let it idle prior to shutdown. I don't have it handy at the moment but it also states that after working, to taper the rpm down rather than instantly.
   / cool idle..... #29
</font><font color="blue" class="small">( The original question was pertaining to a diesel engine. And some manufactures do say on a diesel to cool down. I have never seen a manufacture say a gas engine needs to cool down.
)</font>
Nor have I, but I've never seen any manual for a turbocharged gasser, either.
What would cause a diesel to be more prone than a gas engine to ill effects from shutting down too early? I would be more inclined to give a five-minute idle a D-19 gas Allis Chalmers tractor after using it to plow than I would to idle a Kubota that's been pulling a wagon.
Since cooling off is the issue, I don't think the rules are governed soley by the fuel being burned.
   / cool idle..... #30
</font><font color="blue" class="small">( I would say that the gas engines produce as much heat at idle as they do under a load. Its always working against the throttle plate, c <font color="blue"> </font> reating a load in itself. )</font>
Didnt this make sense????
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
