Soundguy,
The manual says, "Periodically check for oil level in the transmission box and top up as necessary (grease to be SAE90 viscosity). Oil change in the transmission box is to be made every year."
So, which is it.....oil or grease?? The chart Mark kindly referenced in his post lists grease by grade, not weight. I think our foreign friend translating the English part of the manual meant to say 90 weight oil, not grease. After all, most gear boxes use gear oil, not grease, right??
Your comment, "Remember that lots of grease guns will pump oil as well." got me thinking. I've only used grease zerks for grease, but maybe my scope of experience is too limited. The manual is ambiguous, but leans toward using oil, in my opinion. The zerk threw me off, though.
Anyway, after several squirts of grease, and rethinking what I was trying to lubricate, I switched over to John Deere 80-140W gear oil. I got about 4 or 5 squeeze bulbs full (probably half a pint) in, after removing the zerk, even with the grease in there.
Perhaps, the zerk hole is supposed to serve as the fill line.
All in all, I feel much better having good gear oil in the "transmission box" instead of just several squirts of grease.
OkieG
