jim_wilson
Veteran Member
- Joined
- Jun 13, 2004
- Messages
- 1,791
- Location
- Northeast MA
- Tractor
- Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I have a project coming up that I think would go a lot easier if I had a winch to help out with. I have a BX23 with the high amp alternator and was wondering if one of the Warn (or other brand) ATV style winches would work on the tractor. I need to go back and look at the specs but if I remember correctly the winches talked about using some pretty high amperage - and the truck mounted winches used even higher amperage. Is there some way I can figure out how heavy duty a winch I would be able to run with the electrical system on the tractor? I am not averse to putting a higher amp battery in the tractor if that is what it would take to make this work.
