SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,730
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Wow! Ive been using my "baby" one and just as I had something to update the thread comes back up. I see from the angle of the rotor grease fitting that youre threadinjg them in now. Mine, pressed in, were all pointed straight outward on a radius. Off angle is better because straight out gives the grease head a fulcrum point on the aligned carriage bolt head and thus more possibility of inadvertent abuse to the fragile purchase of a pressed fitting.
,,,Two reasons for the update. First, I wanted to say that the Loctite fix using product #638 Retaining Compound is effective at securing a dislodged fitting. ... I regreased the aerator yesterday and the glued fitting did not move, even tho I had done the fix with rather haphazzard cleaning. - One of the other fittings did move tho and I did a more thorough prepped fix on it. Im satisfied that this is handled effectively with little effort.
-- The second issue is grease related as well; the lefthand pillowblock will not take grease into the bearing. The problem was evident since I used a manual gun this time. ... The righthand bearing takes grease easily and when full the grease appears at the seal wiper. The left requires great effort to move grease, and ~1 pump will bring grease out between the case of the bearing element and the pillow block. == Im assuming a misalignment between the supply and feeder holes. This should probably be checked out up front as the unit is assembled.
,,,I know that the bearing will last for a good while w/o grease in this application, but dust and occasional water will fail it prematurely without the grease flushing action. I will disassemble and fix it this winter, and also put a fitting in the center pivot/tie in brace to the 3PH. Get this thing right it should last a lifetime with just grease and core tines.
larry
larry
