Could this be the cause of my unidentified squeak?
   / Could this be the cause of my unidentified squeak?
I also found a zerk that I hadn't found before when I was taking that picture - greasing that will be the next step then.
Back in February, I re-checked all of the lug nut torques and such. I checked a whole lot of things, but not the tie rod ends or the zerk that I've been missing.
So if it ever stops raining around here I'll give that a try.
   / Could this be the cause of my unidentified squeak? #12
If the squeak persists after greasing all zerks, look for a crack in the rim hub.
   / Could this be the cause of my unidentified squeak? #13
repeat :confused3:
   / Could this be the cause of my unidentified squeak? #14
You don't say what kind of tractor this is, other than TBD, but since it's orange, I guess Kubota. If I recall, the front axle pivot on Kubotas (at least some...) have a zerk and a plug that should be removed when greasing.
   / Could this be the cause of my unidentified squeak? #15
Actually 2 zerks, one in the front and one in the back. The front one requires you to remove the plug and pump in grease until it starts to come out the hole
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
NEW Fork Extensions (A53002)
NEW Fork...
378812 (A51573)
378812 (A51573)
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
