Could use some help with digging a pond
   / Could use some help with digging a pond #21
Let us know the cost on that liner , pump and filtration system. Still curious as to what you are going to use as a water source.
I have unlimited irrigation for 30 bucks a year
100 gallons per minute. Im good on the water LOL
   / Could use some help with digging a pond #24
Is that from a 3" or 4" mainline? Must be nice to have that kind of irrigation setup.
   / Could use some help with digging a pond #25
I had many questions, but you seem to be well underway. I have dug many ponds with great success. I was going to ask type of soil, location, room to move spoils, and depth. 4-5' deep is a bit on the shallow side especially when it comes to cattails and weeds in general. Bad soil (quick drainage) can also break the bank. Most pros will do a test dig 1st just to see what they're dealing with, if it's clay great if it's sand not so great. If you are going to stay shallow then one suggestion may be to line the sides with lime, there are companies that have trucks just for this application. There are all different types of ways to line the pond, pretty much depends on what your price range is and what is avaible. Put an add in the paper(craigslist) and see if anyone close by has clay. Sometimes you'll find clay for free, you'll just have to figure trucking. Don't forget a lined pond could have an issue when it comes time for cleanup/dredging(that would be down the road so not a major deal now). Also if you line your pond make sure you dig deep enough to allow for the extra clay or........ what ever you use.
As far as digging it yourself don't be discouraged about the nay sayers(they're just jealous :D), if you enjoy it then have at it, after all it's your time and equipment. Just keep in mind there is more to a pond then just a hole in the ground, as you are learning. My hat is off to you or anyone else willing to atleast give it a try, in the end you'll have learned something and hopefully have successful stories to brag about :)
   / Could use some help with digging a pond #26
I would think a dozier/dozer? could whip out the pond and roll the berm with in about 6 hrs.
Less wear and tear on the tractor and someone that may have done the same job before, and may know what you need in additions, like clay, lime, or liner..
   / Could use some help with digging a pond #27
Perhaps you might want to dig with BH on bottom of pond as deep it will go to see what type of soil there is down there. Also dig somewhere else on the property where there might be clay in a poor draining area or poor growing soil conditions. Finding your own source of clay is your best bet/solution at this point to line your pond with. :thumbsup:
   / Could use some help with digging a pond #29
I forgot to add you should try to go for a 3 to 1 slope, for every 3' out drop a foot. The only place I'd have a drop off would be at the edge to help control weeds.
Loader Forks (A56469)
VITRA FRESH PRO REFRIGERATOR W/ DRAWER FREEZERS (A57192)
VITRA FRESH PRO...
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
