Santa Craig Cringle
- Joined
- Mar 3, 2014
- Messages
- 205
- Location
- Lawrence County, AL
- Tractor
- Current - 2021 Kioti CX2510, Previous - 1959 Ford 881
1. What are some impacts of having a positive ground versus negative ground for battery charging and other maintenance? I bought a 6V battery charger the other day and the instructions say hook up the negative clip to the negative terminal and the positive clip to the engine somewhere. I was visiting some other forums today and most everyone said positive to positive and negative to negative regardless of ground, so it's a little different.
2. How long should the tractor have to run before it fully recharges the battery?
3. I have a battery tender labeled for 12V which I use on my lawn mower. Am I correct in assuming you cannot use a 12V tender on a 6V battery safely?
Background, I have rust in the fuel tank that I think is causing my tractor to frequently die and/or be hard to start. Runs and sounds great when it's going otherwise. However, it frequently dies and I'm constantly cleaning out the carb bowl. Until I get time to work remove, clean, & do whatever to the tank, I need my battery to carry a full charge. Hence the questions.
