Covering Tractor Outside
   / Covering Tractor Outside #11
TL- Fordlords is south of Buffalo, I'm just a hair north, so we know snow. The Rubbermaids hold up great to pretty much anything you throw at it.
I'm considering putting up a shed, I have to see what my restrictions are, but I may do it this spring.
Yeah, it does snow there :)
When I was in the Navy, I spent 6 months (Jan through June) in 1986 at General Electrics Farrell Road Plant going to a factory school.
You haven't seen snow until you've seen Lake-Effect snow !
-Larry
   / Covering Tractor Outside #13
TractorLarry said:
Sounds like a good idea. Thanks!
I wish I could put in a shed, but the one's I've found that are small enough to fit where I can put it (about a 7X7) don't have door openings big enough.
Need 64" or so. Biggest so far has been 60".
**** 48" deck :)
I wish someone made a specialized "Tractor Cubby".
It would look something like an oversized Dog Carrier, and the top would open up and back, and the front would drop down and act as a ramp. You would open it up, drive the tractor in, get out, and then raise up the back door/ramp, then put the top down and latch.
The whole thing could be done in a 6ft wide by 7ft long by 3ft high package.
No need for a carry handle though. Tractor is 1000 pounds wet :)
-Larry
Your 40 years to to late on this.
In 1966 I built exactly what you just described to keep my new 1966 Bolens Tractor in.
   / Covering Tractor Outside #14
No matter what you use for a shelter, put down a 6 mil plastic sheet to keep the moisture from coming up from the ground.
Dusty
PS.... LB.. do you still have that 1966 Bolens? What model is it?
   / Covering Tractor Outside #15
Dusty
Yes I do.It has a front blade that i leave on it all of the time.It's an 850 model.
I also have a 1967 850 just like it I bought in june of 2005 It has a rear tiller I leave on it all the time.
   / Covering Tractor Outside #16
I can see leaving a blade on all the time, but why the tiller? How often do you need to use the tiller? I have a HT23 with power steering, oil cooler, tiller, 54" blade, 54" mower deck, and 3 point hitch, that hasn't seen the light of day in 5 years. The Kubota is all that I need. Probably should just sell the Bolens and get it out of the barn. I sold the cab and 48" snowblower last winter.
   / Covering Tractor Outside #17
Very often
What model is your Bolens?
   / Covering Tractor Outside #18
Very often
Answered before you asked..:D :D
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
2019 CATERPILLAR 262D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
