Cracked Slab
   / Cracked Slab #11
I put a new roof the house about two years ago and had noticed some rot in the upper plate and header where the rafters met up with the chimney. Was unable to access it from the top so I finally got around to pulling down the fireplace face brick and started working the wall.
The plate and header have pulled apart as well as some gaps around the storm door. I was still convinced it was the brick that had contracted from the drought and nothing more. It wasn't until a threw the level down on it that I felt like Rick Perry in a debate, Oops!
I've contacted several foundation repair companies and have been doing some research, but am still uneasy about the whole ordeal. Anybody have experience in this area?
Soil moves because of moisture in the soil. Different types of soil hold more water then others, and the degree of compaction of the soild will decide how much moisture gets into the soil. Most people blame dry conditions for cracked foundations and cracks in their walls, but that is rarely the case. What usually happens is the soil gets really wet and then the ground freezes. Just like an ice cube in a tray, when when soil freezes, it moves things. I believe it's called Frost Heave. It's why homes up north have basements. To avoid or fight this movement, you have to have a foundation that goes below the point where the ground freezes.
You need to post pics of the damage to the foundation, but even then, it's just guesswork on our part. Keeping your foundation dry and making sure that water slopes away from the house is very important.
Every soil type has a load rating. It can hold so much weight. A solid brick fireplace is very heavy and it needs a very large footing to support it's weight. The soil under it needs to be virgin, or highly compacted. Compacting soil is a science and the only way to know if it's done right is with a specialized tester. Don't confuse hard dirt with compacted dirt!!!!
Just about every foundation repair company is a scam. They are by far the worse of the worse in the trades. You need a soil engineer to dertermine what is going on, and how deep and wide your footing needs to be in a repair situation. You can always dig it out yourself and go crazy over doing it, but you are not going to find a repair company that will do this for you. Anchors and cables do nothing to correct the problem. They just mask it and help hold your house in place, but the inablity of the soil to support the load or movement from frost heave is always the problem, and it's what need to be addressed if you are to fix it.
Depending on how old the house is and what kind of money you want to spend, it might be just as well to tear down the chimney and build a new one. You don't have to have brick. A stainless steel one is lighter and easier to build. You can frame around it and put up brick vineer for the same look, or go to rock or Hardi lap siding.
There are options, and I would highly caution you agaist hiring a foundation repair company to do anything.
Eddie
   / Cracked Slab #12
Yes, brick does expand and contract with the seasonal changes, that's why they put expansion joints in brick walls(except for guy that bricked my house. I had to come back later and cut the joints in).
I've never heard of bricks on a house needing expansion joints. There are a lot of brick houses and office buildings here that do not have them. In fact, I've inspected quite a few brick structures and never seen an expansion joint. I wouldn't put them in, and I sure wouldn't have them cut into an existing building. I can't imagine how that would help anything, and I would expect it to cause quite a few issues down the road.
I'm not sure what you mean by an expansion joint in a brick wall? Are you refering to it being built in sections to allow for movement in the soil?
Do you have a link that supports your view that bricks expand and need expansion joints?
How did you compensate for the loss of integrity by cutting the bricks?
What did you do to keep water and bugs out?
Eddie
   / Cracked Slab #13
Way too little info to get an accurate idea of what the problem is, and I've been working on masonry chimneys for 30 years.
Brick does not contract to any degree that could be noticed in a chimney.
You already ruled that out I know.
Sounds like, and this is assuming we are talking about a chimney on an outside wall, there were no wall ties installed. these are metal straps laid between the courses of brick, every couple of feet in height, and fastened to the wall as the chimney is being built. With out wall ties, even chimneys with adequate foundations can move away from the wall. That movement will always be away and keep building a greater gap. We have strapped chimney back to the house plenty of times, to stabilise them and prevent further movement.
You could spend money on beefing up the foundation, but you can't move the chimney back. And you will still need to "tie" the chimney to the house, now with some type of external strap.
Those little ties are worth there weight in gold, I've seen chimneys that pulled away from houses with perfectly good foundations, for lack of wall ties. And I've seen chimneys stay in perfect place with very poor foundations, due to the use of wall ties.
I'm making alot of assumptions here, I hope I'm not out in left field.
My idea is based on my experiences over the years.
images
images
JB
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
3in Poly Pipe (A49461)
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2010 EVCO SERVICE CO., INC. SWIVEL UNIT (A50854)
2010 EVCO SERVICE...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
