Craftsman 18 hp hard to turn over?
   / Craftsman 18 hp hard to turn over?
Is your engine an OHV engine which has easily adjustable valve or the old L head engine which does not?
This one must be the old one, the valve is in the block. I took the plugs out, it doesn't seem to be a compression problem. It didn't turn over very well. I have a new starter and solenoid, and I am using a battery charger to turn it over. It should be really spinning. I am debating what to do next - junk it, pay somebody to rebuild the motor, or ??
   / Craftsman 18 hp hard to turn over? #12
Like Dana Warner said, jump start it from a vehicle. Try it without plugs. Don't burn out your starter.
   / Craftsman 18 hp hard to turn over? #13
I'm sure others will disagree with me but battery chargers are not designed to be used in place of a battery. If you want to test the operation of your starter you should be jumping the starter from a good battery. Even a bad battery can cause you to have starter symptoms. I would suggest you remove your bad battery from the circuit and jump directly from a good battery. The battery charger is ok to be used as a boost on a weak battery but should not be used in place of a battery.
2003 Club Car Electric Cart (A50324)
2003 Club Car...
RoGator 844 sprayer (A50490)
RoGator 844...
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
