Craftsman 18 HP Sputters and quits.
   / Craftsman 18 HP Sputters and quits. #11
Thanks Jim. Sorry I didn't respond sooner but got busy. If I understand your post corrctly it sounds like the solenoid could be bad intermittently, if an intermittent failure is possible. Thanks again for your time and response.
I suspect that if a solenoid were operating intermittently, a bad electrical connection or something else is causing a power interruption to the solenoid. In my experience, the most common problem results from varnish buildup and can be corrected with a good cleaning.:thumbsup:
Jim
   / Craftsman 18 HP Sputters and quits. #12
I had a simalar issue on weedeater BS 18hp tractor. I took the "float bowl" off and solenoid off. found the bottom of bowl is full of rust and solenoid sticky from rust. I sprayed the plunger with wd40 and played with plunger from soleniod until the spray ran clear and plunger moved freely. everything was fine since.
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2008 Chev Impala (A51694)
2008 Chev Impala...
