Craftsman Cordless Drill
   / Craftsman Cordless Drill #1
BB_TX
Veteran Member
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
I have a 15.6 v Craftsman drill that I bought 5 years ago. I built my metal shop with it putting 1000+ self tapping screws. And have used it extensively since. It has been dropped off the building, bumped, and generally used hard and still works great. I am very happy with it. Now the problem. One of the two batteries has finally died. I priced the batteries at Sears and they are $49.95 each. A new drill just like I have complete with 2 new batteries, charger, and a drill bit set is $69.95. What is wrong with this picture. /forums/images/graemlins/confused.gif Do I just buy a whole new drill? Or is there an alternate source for batteries for a cheaper price? I suppose I could just buy a new one and have 2 drills, 2 chargers, and 3 batteries. /forums/images/graemlins/crazy.gif
   / Craftsman Cordless Drill #2
I've noticed that on all the cordless batteries. Doesn't make much sense to me either.
For 70 bucks, I'd go the new route.
   / Craftsman Cordless Drill #3
I am in exactly the same situation myself this summer. I have a 15 year old DeWalt cordless drill (12 volt), and one battery is completely dead, the other only lasts for about 20 minutes, and is weak. A (single) replacement battery will run me almost $100, but I can get a new 14.4 volt unit with two batteries for under $150, or a new 18 volt with two batteries for under $200.
I am going with a new one /forums/images/graemlins/grin.gif. I just need to decide if the weight of the 18v is worth the extra power.
Dave
   / Craftsman Cordless Drill #4
There are companies that rebuild battery packs. They usually can do it for less than the cost of a new one. This service is heavily advertised for laptop computers, and may or may not be available for drill battery packs. Google should reveal whether it is or isn't.
In the past, I have been able to replace the NiCads themselves in some battery packs, although I have never tried it on a drill. It usually ends up looking like a hack job, but it works. Whether or not it is feasible depends on how the pack is constructed, my ability to get it apart without completely destroying it, the type of cells inside, and their availability from a quality source.
Usually, only one cell is bad. It is best to replace them all, but I have been able to obtain satisfactory service by just replacing the defective cell.
I have a friend who guts his defective 12 volt drill battery packs and solders a power cord to their contacts (on the inside, natch). He then solders either alligator clips or a cigarette lighter plug on the other end and has a drill he can use on car or boat.
That might work on 15.6 volt drill--producing slightly less power--or it might not work at all.
   / Craftsman Cordless Drill #5
</font><font color="blue" class="small">( I suppose I could just buy a new one and have 2 drills, 2 chargers, and 3 batteries. /forums/images/graemlins/crazy.gif)</font>
That is what I would do. That way you can have a drill in two different locations as well. G
   / Craftsman Cordless Drill #6
I have the same dilema, with a DeWalt. I actually bought a portable saw with two batteries (12v) and now have 3 bats for two tools. But, I also added another portable drill and went to 14v, and learned the batteries don't last near as long as the 12v, (so use the 12v for most of my work). Replacements are in the neighborhood of $50 (checked today, $49) for the DeWalt. Have not seen the $100 price for them.
I'd be interested in the approach to replace the dead cells, if anyone knows the clever ways how to do it. /forums/images/graemlins/smile.gif
   / Craftsman Cordless Drill #7
<font color="red"> (I'd be interested in the approach to replace the dead cells, if anyone knows the clever ways how to do it.) </font>
You carefully work the pack apart by prying on the seams. I've never been able to do it without at least cosmetic damage. Note any temperature sensors and how they are positioned in the pack.
Once apart, measure the voltage across each individual cell. The bad cell will be markedly different than the rest.
Obtain a physically and electrically identical cell and solder it into the pack, replacing the bad cell. The cells are often spot welded together using short jumper bars (for lack of a better term). Usually, these can be replaced by copper wires.
Reassemble the pack being careful to get any sensor back into the same position. Use model cement or the like to reglue the seams. If necessary, wrap pack in a thin layer of electrical tape to help hold it together.
   / Craftsman Cordless Drill #8
SnowRidge
Thank you for the tip. I will try that approach. Have to do some searching for replacements, but maybe the local battery shop or Radio Shack will work.
   / Craftsman Cordless Drill #9
beenthere -- I use RipShack batteries, of any kind, only in desperation.
   / Craftsman Cordless Drill #10
Had the same situation with my Makita 12 volt drill, could get a new drill with two batteries and charger for less that what two batteries cost. That is why I now have 3 drills. Actually the extra drills come in handy, I can leave the screw driver bit in one, the pilot drill in another and a clearance drill in the 3rd. Easier to switch the battery than the bit /forums/images/graemlins/smile.gif
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
