cross over relief valve
/ cross over relief valve #1
bubbacuse77
Platinum Member
Wisconsin
John Deere 3520, John Deere X749
guys, I am getting conflicting info from my research. can I use a cross over relief valve on a dual acting cylinder?
/ cross over relief valve #2
You could but why?
Why would you want to? The valve controlling the cyl will provide the relief.
How would you use it ?
I'm building a new FEL plow from an old 6 foot meyers I found for $100 dollars. I am about to send it for powercoating and was looking into the hydraulics and notice guys talking about crossover relief valves for snow plows.
I used one dual acting cylinder instead of 2 single acting. I just don't want to hurt anything in the hydraulic system.
How will the valve provide the protection? Does it transfer the fluid from one side to the other as needed?
Why do more people not use one larger dual acting cylinder vs the 2 single acting ones guys use for plows?
/ cross over relief valve #4
Yes you can.
How is that JJ?
You are probably going to want the Xover to work at a much lower pressure than anything in the valve would relieve at.
/ cross over relief valve #5
Bubba... yes you can install one... and YES it's needed in the system, if you are plowing and fetch the corner of the plow on a curb, it's nice to have the hydraulic cylinder give instead of something REALLY expensive. These are easy to get and simple to install. just look on the prince hydraulic site or sun hydraulics..Jim
/ cross over relief valve #6
You could but why?
Yes, you can.
A common spool valve has no relief available to the work ports while the spool is in the neutral or hold position.
An excellent reason to use one on say, a snowplow angle circuit.
/ cross over relief valve #7
Call me crazy but I dont see the crossover being effective on a DA cylinder.
There is more volume on one side VS the other. So IF you are angled so that the cylinder is extended, and hit something, and the crossover allows fluid to bypass to the other side of the cylinder, well....that side isnt large enough to hold all the volume of fluid comming. So then what?
I would think a PRV built into the system between the valve and cylinder would be best.
But I am no hydraulic expert. Just throwing out my thoughts.
Why not use the two single acting cylinders like it was set up for?
/ cross over relief valve #8
/ cross over relief valve #9
LD1,
you are correct in that X-over RV provide a limited protection on DA cylinders. If the cylinder is fully retracted it can fully extend but will draw a vacuum on the blind end. If Fully extended it will only retract part way do to the volume difference.
JJ,
Yes port RV's will work except they again may or may not fill the other end of the cylinder with oil. Also depending on hose length and valve position they may be situated far enough away that they might not see the pressure spike before some thing bends.
Roy
/ cross over relief valve #10
Oldnslo and LD1 are on the right track
one double-acting hyd cyl has different displacements on each side.....two single acting cyls are best or....... 2 double-acting cylinders plumbed cross-ways (rod end on one side tee'd to base end on the other.....and vise-versa)
definetly need a cross-over relief valve for a plow otherwise an induced load (ie: curb or manhole cover) will put a serious hurt on equipment.......BANG...:mad:
/ cross over relief valve #11
Crossover will protect ONLY the extended plow edge by diverting the oil to the retracted side.
Plow snow to the curb and hit the curb and there is no protection
Plow away from curb towards center of the road and you are protected from curb blows .
Pushing with plow straight and both corners are protected.
The usual crossover setting is about 1500 PSI on plows, but most are adjustable somewhat.
/ cross over relief valve #12
Fisher Insta-act Plows set their main reliefs at 1750 psi and the cross-over reliefs at 4000 psi ( max rating of hyd cyls)
/ cross over relief valve #13
Meyers Electrotouch E-47 main reliefs are set at 1650 and the X-over-PRV @ 3000psi
Here is what Prince has for a product description. Looks like it is not only a cross over but a cushion valve as well............what is a cushion valve?
The PRINCE valve model DRV is a differential poppet type double relief. The double relief is used in systems that require cross over relief protection such as a reversible hydraulic motor, or systems that require a cushion valve such as double acting cylinders.
/ cross over relief valve #16
A cushion valve bleeds some pressure through a orifice to keep from an abrupt slam at the end of the cylinder stroke, mostly towards the last inch of travel or so. Depends on application that you would be using it for.
/ cross over relief valve #19
Hmmm,. now this post has me confused. I have a new Quick Attach loader mounted plow that i have never used before. I simply attached the double acting cylinder into my rear remote port. Am i supposed to add a cushioning valve or ???? also?
thanks
/ cross over relief valve #20
thanks
Well thats what I have , spring loaded mold board, no cross over valve and in 20 years no issues. I do not have curbs.
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2023 Global Trailers GT302 30ft. 60YD T/A End Dump Trailer (A61568)
2023 Global...
SD Lanch SDLG80 Electric Golf Cart (A62177)
SD Lanch SDLG80...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
LandHonor LHR-EW20000 20000lb Electric Cable Winch (A60352)
LandHonor...
