CT230 2013 HST tractor
   / CT230 2013 HST tractor #1
cpet9628
bobcat CT230 2013
Every time I go to use the lights the gauges die including tach, and I never get he lights to come on. only the flashers work. After abit everything come back to normal. Never get lights to come on though. Machine starts does everything I need it to do but no lights. Can't figure it out. I don't know if it is a bad ground or something to with ign switch.
   / CT230 2013 HST tractor #2
At a guess without further info sounds like a short to me with an auto-reset circuit breaker in the circuit
auto rest circuit breaker? Well that makes sense. I have looked at light switch and it seems fine but very difficult to get tester on it. same with ignition switch
   / CT230 2013 HST tractor #4
I would pull the plugs to both headlight bulbs, then check for continuity to ground at the + side of each connector. You can't do them one at a time -must be both disconnected before you start checking because a bulb is a resistor to ground.
If you have continuity to ground it means you have a short in the system. If that's the case, then disconnect the headlight switch and check again -if no more continuity to ground replace your switch. If still continuity to ground you have an issue with your wiring or headlight relay if you have one or with your auto reset circuit breaker if you have one. Just keep disconnecting and testing in sequence to logically isolate the problem.
Here is a common type of auto reset circuit breaker: I would look at your wiring diagram to see what your starting circuit has
   / CT230 2013 HST tractor #5
Looks like you have both high and low beam relays
And all fuses no auto reset circuit breakers:
I would be suspicious of those relays or your headlight switch. All of which can be pulled and tested individually
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2010 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2010 WACKER NEUSON...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
