CT230 Cruise Control
   / CT230 Cruise Control #1
CT230 Fan
Stewartsville, MO
Bobcat CT230
I haven't been able to get my cruise control to work on my CT230. From what I understand, you just have to get up to speed, and then flip up the green lever. When I do that, and take my foot off the pedal, I just come to a stop. Am I doing something wrong here, or do I have an issue? I honestly don't know if I will ever use the cruise, but I was testing out every function, and this one wasn't working.
Thanks for any info.
   / CT230 Cruise Control #2
Ive only tried mine once like you just to see if it worked and I did exactly what you did and it seemed to work fine. Does your instrument cluster display the cruise engaged?
I didn't see anything light up, but I didn't think about that. I will double check that and see.
   / CT230 Cruise Control #4
take a look at the rod that the green lever pulls. there are 2 nuts on it....try adjusting the nuts further up (not down) That should do it...
I will take a look and see what I can do. Thanks for the advice.
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
MULCHER (A58214)
MULCHER (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
