CTL 70 accessory Hydraulics not holding?
   / CTL 70 accessory Hydraulics not holding? #11
If you install 1/4 in QD's, in a tee in each pump circuit, you can just plug in the gage for each pumpyou want to test. It will show the actual pressure being developed by a cyl or motor.
The gage will reflect the pressure developed, if any for any hyd evolution.
The hyd test sets above were built from parts,.
Just a gage, reducer fitting and a QD. The other one added a short 1/4 in diameter hose from 12 to 30 in would be good.
I think I figured it out today! I was working the control and found that the noise I am hearing is coming from the supply line running down the lift arm. Right before this happened I had the aux couplers off because one was broken. I wonder if the cause of this is air in that line? Does that sound reasonable?
I plan to hook it to my brush mower and run it for a bit. That should circulate the fluid and pull any air out with it?
JJ does it sound like that will work to move the air out? I can't think of any other way to do it. Right now I think it is just pushing the air back and forth in the main line and then compressing when I hold the button down?
   / CTL 70 accessory Hydraulics not holding? #14
Yes, that should work.
Appears we have success! Ran much better today.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
