Comparison CTV TO HST COMPARISON
   / CTV TO HST COMPARISON #1
bironacad
Platinum Member
Southern Ontario, Can
New Holland 3045/2010
I just got a quote on a Boomer 3040 tractor with a factory CAB and was told the cab model only comes with the CTV transmission. Being new to this I would like to know how the two transmissions differ in operation and what are the Pros and Cons. I have an HST transmission on my Cub Cadet but have never owned something with a Constant Velocity Transmission.
Thanks in advance!
   / CTV TO HST COMPARISON #2
I have a HST tractor(Kubota) really like it compared to gear;haven't used the CVT tractors but:recently purchased a 2010 Subaru with the CVT and found it amazing.This is fairly new in tractors,check the NH forum for new users.I know on the Subaru forums a lot of people were concerned about durability.......time will tell but I am confident.
   / CTV TO HST COMPARISON #3
I had a Subaru Justy with CVT about 20 years ago IIRC. the advantage of CVT is that it always uses the "gearing" to give you maximum torque. So it should be great on a tractor. Snowmobiles use CVT and it works wonderfully in that application. How durable it is I can't say.
   / CTV TO HST COMPARISON #4
You might want to look at some of the other posts here about the cvt transmission and the issues starting to surface with a breakout while pushing heavy loads.
   / CTV TO HST COMPARISON #5
Would you please explain?
I did a quick search and couldn't find an issue pushing heavy loads. What do you mean by breakout?
   / CTV TO HST COMPARISON #6
ive ran the HST tranny for 3 months an i love it.i dont know anything about the CTV tranny.i to have a kubota.
   / CTV TO HST COMPARISON #7
Sold my hydro and bought a CVT, the only problem with my CVT is it took some time to get used to. The CVT puts more power to the ground than a hydro in my opionion. Also seems to be much better on fuel. The New Holland cab is AWSOME! I don't think I'll be going back to a hydro anytime soon. Hope this helps.
   / CTV TO HST COMPARISON #8
Most concerns vanish with proper operator training, transmission settings to fit the tasks, and a proper calibration of the transmission at predelivery. Dealers that rely on the 'quick and dirty' factory transmission calibration will have dissatisfied customers.
   / CTV TO HST COMPARISON #9
Is there a significant cost differential between HST and CVT?
   / CTV TO HST COMPARISON #10
Thanks in advance!
There are some folks that post here at TBN who can explain in technical detail how both HST and CVT transmissions work. I can't give you all those details, but here's a summary that might help you get started, at least.
1. HST... Instead of using a series of transmission gears and shafts to transfer force from the engine to the drive wheels like a standard gear setup, the HST drive uses the engine to drive a hydraulic pump which feeds fluid to a hydraulic motor that makes the wheels turn. The advantages: clutch is no longer required, continuously variable "gear ratios" by using a simple foot pedal control valve to control the flow from pump to motor, easy changing from forward to reverse. The disadvantages: the hydraulics aren't as mechanically efficient as a gear drive so some power is lost, same issue means it's not the best for extensive heavy tillage work, and the whole thing is more complicated than an old fashioned gearbox.
2. CVT... An innovative gearbox design that achieves the same continuously variable gear ratio advantages of HST using mechanical means. Supposedly operates with higher mechanical efficiency than HST.
Don't know enough to comment on disadvantages.
HST has been in wide scale use in tractors for more than 30 years and seems to be basically as reliable as conventional gearbox transmissions. Just my opinion, but each depends more on how it's used than one being inherently better than the other. CVT is more recent, particularly in smaller equipment, and does not yet seem to be at the same stage of technological maturity (again, just an opinion... others may not agree). It seems to be a promising new approach, but there may be some teething issues still being worked out. HST's are probably the most common setup in tractors under 60hp today and are widely available from the leading manufacturers; I think NH is the only manufacturer with a compact CVT tractor so far.
I'd invite you to check out both types and come back to TBN with your observations. I'm sure that would bring on a lengthy, animated thread everyone would enjoy and learn from. And good luck with your tractor shopping adventure!
Variable Speed Conveyor Belt (5.5ft) (A46877)
Variable Speed...
Toro Z Master 5000 60in Zero Turn Mower (A44572)
Toro Z Master 5000...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
2014 Chevrolet Impala Limited Sedan (A44572)
2014 Chevrolet...
2021 Ford Explorer AWD SUV (A44572)
2021 Ford Explorer...
