Oil & Fuel cub 7264 deisel 4x4
   / cub 7264 deisel 4x4 #1
robert born
hello does anyone have a wiring diagram for the wire that feeds the fuel injection pump solenoid on a 2003 cub cadet 7264 with a diahatsu diesel 26hp please send to me please thank you i dont want to strip the whole harness trying to trace the wire by color thank you
   / cub 7264 deisel 4x4 #2
All the 7000 series diesel tractors share the same wiring and dash. I believe you're talking about the fuel shutdown solenoid and it has two circuits that go to it. The first one is for the pull coil on the solenoid and it fed from a terminal on the starter motor. The hold coil on the solenoid is fed from the accessory circuit from the key switch.
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
1999 International 8000 Semi Truck (A59814)
1999 International...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
