cub cadet 3000 only moves with diff lock
/ cub cadet 3000 only moves with diff lock #1
fullacresfarm
ny
cub cadet
I recently got a 3000 series cab cadet from my family used it for two days and now it only moves with the dif lock engaged fluids full and all the adjustments for the petals are correct still doing the same power steering and lift still work as they should
/ cub cadet 3000 only moves with diff lock #2
Broken axle? With one axle broken, that would certainly be one scenario that could cause this.
If I have it jacked up in the air it will go but I can stop each tire by hand if I'm not using the diff lock
/ cub cadet 3000 only moves with diff lock #4
Time to break out the wrenches, and open it up.
That's what I thought just didn't want to jump into it and didn't have to
/ cub cadet 3000 only moves with diff lock #6
That is actually normal for an open diff.
If you have a broken axle (or something similar), you should be able to stop ONE of the tires when the diff lock is on. This type of diagnosis can be difficult if things are bound-up with broken stuff.
Not being able to move unless the diff-lock is on... is a pretty good indication that something is broke...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
LOOK! (A63109)
LOOK! (A63109)
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
Takeuchi TB225 (A62177)
Takeuchi TB225...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
