Cub Lo-Boy intermittent misfire
   / Cub Lo-Boy intermittent misfire #11
If it isn't used much I suspect the distributor cap, points and rotor. Moisture can condense inside the cap and cause all kinds of problems.
I have an M with a loader that gets used 3 or 4 times during the summer and more often in the winter to plow snow. It gets all new ignition parts everyother year, otherwise I'm chasing problems just like you are now.
I've been using the tractor in some heavy grass and it continues to run perfectly. I couldn't quite bring my self to smoke up the place with the ATF as suggested by Soundguy, but I split a pint of Seafoam between the gas tank and crankcase. Going to do a oil/filter change this weekend.
I think it may have been a stuck valve. I'll let you know if the problem returns.
Thanks,
   / Cub Lo-Boy intermittent misfire #13
a lil atf mighta made that sticky valve happy.. half in oil.. half in tank..
soundguy
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
JOHN DEERE LOT NUMBER 110 (A53084)
JOHN DEERE LOT...
20' BI-PARTING GATE (A51248)
20' BI-PARTING...
