cultipacker weight/horsepower
   / cultipacker weight/horsepower #1
Oldstuff
Missouri
'63 Ford 2000
I have been keeping an eye out for a cultipacker about 6 foot wide (no less) in order to cover the wheel width of a Ford model 2000 gas engine which is 36 HP. Up until now I had not given what horsepower is needed to pull a cultipacker since I am looking at it as a rolling load and not to much power would be needed tp pull it. I have a 1 1/4 food plot. So-- what is the max weight I should pull with this tractor and typically what width would that be?
Thanks- Oldstuff
I forgot to mention, since I know about what most 6 foot wides weigh I am assuming I would get a pull model rather than a 3 pt lift mode.
Oldstuff
   / cultipacker weight/horsepower #3
I easily pulled a double 12 footer (that's like a dually). This had weight boxes on it for which I stacked concrete blocks for extra down force. No problem with my 36hp 1070 in 4WD. It gets interesting if you get it out on a paved road or concrete driveway. They like to roll once they get started. Make sure your brakes are in good working order.
I was using it to pack down a freshly seeded alphalfa field. I used my 6' rototiller to 'plow' it up and borrowed a JD grain drill to plant it. The tiller took all day to do a 5 acre field. Multiple passes.
   / cultipacker weight/horsepower #4
Very little hp is needed on a cultipacker. My little 10hp Farmall Cub easily handles my 8-footer. If I had any hills I might worry a bit about that heavy cultipacker behind that little tractor but my farm is as flat as a pancake.
   / cultipacker weight/horsepower #5
I pulled a 12 footer last fall with my 35 HP Deere 4400. It did take a few HP the first time over the freshly tilled seedbed, but no problems at all.
Wayne
Thanks to All for the comments.
Oldstuff
   / cultipacker weight/horsepower #7
Pull type, up to 10 ft would be reasonable. We have about 30 rebuilt packers on hand today, if you want to see pictures, fire me a email at sweet@scrtc.com Ken Sweet
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
1273 (A50490)
1273 (A50490)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
