Cultivator for weed control
   / Cultivator for weed control #1
Mearntain
Gates, NC
Ford 2000
I've been struggling at finding the info that I'm looking for, so figured I'd make a post here. I've recently got some ground ready for planting, but now can't seem to decide what size rows to plant. I know it will depend someone on what will be planted.
I've got approximately 42 inches between the inside of my 2 rear tires. My question mainly is coming down to me wanting to use a cultivator down the road for weed control, but I don't currently own one yet. If I can't find one locally used for a decent price, I was going to get the one row cultivator from Tractor Supply. I don't want to choose an arbitrary distance between rows, and then later find out the cultivator is lined up to where it wants to cut right through my plants.
I figured I'd probably do 2 row seed beds for most of my stuff. Are all cultivators able to be adjusted to your row spacing? Or does my row spacing need to be set off of the cultivator spacing?
   / Cultivator for weed control #2
Our cultivators had tines that were movable. Some cultivators has shields to keep the tines from throwing soil over onto small crops, too.
All was done before gut-disease-causing GMOs that are Roundup ready. If you gotta run over the field spraying Roundup, you can run over the field with a cultivator instead. Same amount of fuel and no expensive Roundup.
Ralph
   / Cultivator for weed control #3
the cultivator i have is just a tool bar that cultivating shoes can be mounted on and is very adjustable. the tool bar has other uses one of which is mounting hilling discs on it to make raised beds or to hill potatoes. i think it is a fred caine cultivator.
   / Cultivator for weed control #4
To calculate your row spacing measure the width of 1 rear tire and add that to the 42" between the tires. That number would row spacing if straddling 1 row. To straddle 2 rows under the tractor divide that number by 2. This will place the tires centered in row while cultivating and you sent cultivator shovel spacing accordingly.
   / Cultivator for weed control #5
Here is a fairly inexpensive cultivator/hiller purchased from Tractor supply.I added the hillers(turned them around since this picture) and they are removable.
Thanks for the replys from everyone, that clears things up some for me. Nybirdman, is the TSC one pretty adjustable as well?
   / Cultivator for weed control #7
Yes: you can remove any of the cultivators.I added "peanut" shares to mine and it works well.
I purchased them from AgriSupply;Had to modify a little.
   / Cultivator for weed control #8
Ralph
I'm not advocating one way over the other, BUT spraying does a much better job of controlling weeds, over using cultivators and you don't have any wore out shoes to deal with... You can cover more rows on the same amount of fuel too.
Also, it's easier to stay in the row too, compared to a 3 point cultivator.
SR
   / Cultivator for weed control #9
Organic vegetable growers will not use Round-UP.I do use a lot of Round-UP,just not in a garden.
Online Buyers Premium (A55272)
Online Buyers...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2012 Ford F-550 (A55973)
2012 Ford F-550...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
