Cultivator sweep stem
   / Cultivator sweep stem #1
Haywire
Central Kentucky
Tractorless :(
Anyone know what size stock the stem on this is supposed to take? It's a bad picture, but looks like maybe 1" square. Here's the agri supply link.
Ian
   / Cultivator sweep stem #2
Those bolt onto a 1 5/8" wide shank. The upper and lower plow bolt hole-centers are 2" apart.
Agri supply sells the cultivator shanks too. The sweeps are made in Brazil. Shanks are made in China.
I only see the C type tine. I was wanting a straight shank, kinda like this Brinly, but with a 10" sweep.
Ian
No, I believe this is what they call the C type. SHANK FOR CULTIVATOR - Agri Supply
I dismissed the one you linked because of the cost. I need 7 of them. What I'm thinking about doing is getting some pieces of heavy square tube, having the ends bent to about 20 deg and mounting the sweeps to them. I'm still running the possibilities around my little brain. I'd like solid bar stock, but steel is crazy expensive these days. Maybe 1/4" wall square tube would suffice.
Ian
   / Cultivator sweep stem #6
Yeah, those one's I linked are pricey. I have two of them for my KEULAVATOR. Not worth the cost if you ask me, not for my purposes anyway.
Yea, I think those spring reset points are made for high HP tractors, not my little 25hp 2660.
Ian
   / Cultivator sweep stem #8
I have a 2920. The springs are adjustable and you can get them to trip pretty easy with the little tractors. I had them set way too loose initially though and they just sprung and didn't reset. I have the 12" sweep which are also too big really. I almost got the 16" sweeps, but luckily they were out of stock on the 16" ones when I ordered.
But, I don't think I would buy them again. I do run them upside down on my bedder as they add some nice weight :)
   / Cultivator sweep stem #9
Ian
If it was me, I would use my new Hiller attachment I just made and a pair of the trip type shanks someone linked earlier. There is more to those than just the trip. Adjustments can be made to make that sweep cut less/more that you wont get out of square stock. Search flea bay for IH cultivator shank 140. I dont see why one would need 7 at one time.
   / Cultivator sweep stem #10
Personaly Id go with 7/9 in, sweeps, and space your tines accoridingly to suit your needs, 12 in sweeps and the like are 4 special use, and offer alot of special problems 2, Eric
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2008 Lexus RX AWD SUV (A55758)
2008 Lexus RX AWD...
2017 Ford Fusion Hybrid Sedan (A55758)
2017 Ford Fusion...
Massey Ferguson 30B Tractor w/Loader (NOT RUNNING) (A50775)
Massey Ferguson...
