Cupholder
   / Cupholder #1
nh1520
DuBois, PA
New Holland 1520
1st Problem: No cupholder on my New Holland 1520 and I am getting tired of holding a water bottle or it rolling around by my feet and end up running over it.
2nd Problem: Locating a "heavy-duty" aftermarket cupholder that would mount to my ROPS so its out-of-the-way and yet easy to mount and also remove. Couldn't find any.
3rd Problem: Large enough to hold a big water bottle and not be able to bounce it out of the holder.
4th Problem: I'm cheap when it comes to things like this.
This is my version on my clamp-on water bottle holder. I have also made them for my JD140 garden tractors. Its made out of 3/4" x 1/8" flat steel. I cut the top and bottom to length then make a "circle" by shaping them round on the horn of an anvil. Weld the circle closed and simply add four (4) vertical pieces to make the cage and one (1) across the bottom to keep the container inside. This is the largest one I've made and the first to clamp on but I wanted easy on - easy off and adjustable (since I've never built something right the first time yet). The welded on "u-bolts" are simply pieces of 1/4" all-thread, heated and bent over a piece of angle iron to size them. The backing plates are little pieces of aluminum angle and I used stainless steel lock nuts and washers. Total cost about $5 and two or three lovely hours of tinkering (had the house all to myself - girls were shopping). Best thing of all I DIDN'T have to run to town to get anything - had enough on-hand of what I needed (I think this was the first time).
If you make them high enough they will hold most containers from bouncing out and the diameter (larger IS better in this case) since additional bottom pieces could be added to keep small containers from falling through. I use the larger plastic water bottles with the pull out with your teeth - suck on tops with water. I tried some other drinks, like pop, but it was flat before I got out of the shed from the vibration. Wifey says I shouldn't be drinking so much pop on hot days anyways.
Anyway, thanks for looking. I've been a member for awhile but although I read most everything - I'm just getting around to posting.
   / Cupholder #2
Do a search here for 'Chalkley cup'. It'll solve all your problems very inexpensively.
   / Cupholder #3
NH1520:
I saw one mounted same place place on a John Deere yesterday. he used a 6" length of PVC pipe with a cap glued on. It was held on to the ROPS with stainless steel hose clamps. the was a 1/4" hole on the bottom to drain the rainwater. And a slit inthe side for a cup handle.
   / Cupholder #4
I'm cheap too.............but my wife saw this at the Louisville EXPO, picked up the literature and ordered one red for my Yanmar and one blue (close to gray isn't it?) for her rider
<A target="_blank" HREF=http://www.stukcup.com>StukCup</A>
Works wonderfully.
   / Cupholder #5
Jerry, I can't get that link to work.
   / Cupholder #6
It's got an extra http in it, lose that and it works.
   / Cupholder #7
Thanks, that worked great. And, for others who have the same problem I did, just click <A target="_blank" HREF=http://www.stukcup.com>Stukcup</A>.
It still looks like an offshoot of the Chalkley cup. /w3tcompact/icons/smile.gif
   / Cupholder #9
I was just thinking... too hot for anything else!
and thought that a bicycle water bottle cage might work well.
Just use some sheet metal screws or the large hose clamps and slip in the water bottle;
<A target="_blank" HREF=http://shopsite.twowheeltransit.com/page103.html>http://shopsite.twowheeltransit.com/page103.html</A>
(I don't know about the above site, just put it in as a reference!)
Anyone ever tried this?
Curtis
   / Cupholder #10
I've made cup holders that attatch to the rops out of large diameter pvc scraps.... 4" pvc with a cap, and a large hose clamp.. works greak.... some elastic, or small bungie can be added to stabilize the bottle, etc.
Soundguy
72In FEL HD Round Back Bucket (A46878)
72In FEL HD Round...
ST225/75R15 Radial Trailer Tires (A47809)
ST225/75R15 Radial...
The Boss Snow Scraper (A47809)
The Boss Snow...
International 3082 Series A Backhoe Attachment (A47809)
International 3082...
TOFT 530 Hyd Breaker Hammer (A47809)
TOFT 530 Hyd...
3 Cylinder Ford Engine (A47809)
3 Cylinder Ford...
