Current spray paint info, for old BX23...
   / Current spray paint info, for old BX23... #1
tshep
Richmond, VA
BX23 MLB
As above, I have an inherited BX23 from 2005 or so.
Looking at tractor and paint chart - Kubota Paint Chart
I seem to have yellow paint showing under orange in a number of places, was expecting to see Yellow Repair Primer listed - but only Grey - good under all colors and types?
Would my tractor be:
Orange - KUBOTA ORANGE II (BRIGHT)?
Frame and such - DARK GRAY ENAMEL?
and ROPS - ROPS GREY?
I have not taken pieces off to hold and match, BUT it sure looks like upper ROPS, lower ROPS attachment frame, lift arms, axles, seat frame, lever and main frames are ALL the same color. Are there 2 colors, which ones, and where is the line between ROPS and other?
THX all!
   / Current spray paint info, for old BX23... #3
THX all!
If you need the Kubota Orange 2 it is available on Amazon for $43.78.
It is XO Rust TTB27-GL, for the gallon size (shipped by Tru Value).
Quarts are also available.
It is a perfect original Kubota 2 match, but of course it will not match, if time and the sun, now have you at "Kubota pink".
   / Current spray paint info, for old BX23... #4
THX all!
The colors you describe are the correct ones for your year Kubota.
If you need the Kubota Orange 2 it is available on Amazon for $43.78 per gal.
Anyone know for sure where the ROPS color 'line' is?
Is it just exactly the upper ROPS structure and all else is the other gray?
Does it include ROPS structure under the body?
   / Current spray paint info, for old BX23... #6
All the gray is the same color, the upper areas might be more faded causing it to look different.
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2010 Toro Workman MD (A55973)
2010 Toro Workman...
